Question about KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer
Food made with KitchenAid Stand mixer tastes like grease
I just used my kitchen aid stand mixer for the first time, and the cookie dough tasted like grease. Is this normal for the first time, or do I need to return it?
My kitchen aid stand mixer is 15 years old and is beginning to give off a slight mechanical burning (??) smell when I use it. At one point during a move oil seeped out from where the rotating part connects to the upper part of the mixer. Could it be that it requires more oil..how does one do that?
Posted on Sep 21, 2009
    Problem Solver:
  • 6 Answers
The k-aid stand mixers do have a tendency to seep oil.
That oil started out as grease but has separated and is probably coming out from around the beater shaft.
Usually just wiping shaft off with a paper towel right before using is sufficient.
Also -the more frequently the mixer is used, the less likely the tendency of the grease to separate.
Posted on Feb 19, 2009
    President:
  • 2,976 Answers
The likelyhood of grease coming from the mixer is extremely small. As long as the beater & bowl were washed first and the shortening you used was fresh, there shouldn't be a grease taste.
Posted on Feb 17, 2009
Kitchen aid mixer kg25hoxer repair manual
Request the repair manual directly from KitchenAid.
Feb 26, 2018 | Food Mixers
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
Where can I get the grease for my Kitchen aid stand mixer?
The grease is food grade grease and Kitchen Aid supply it as a spare part so depending on where you live either from themselves or an Authorised Service Agent. If you are in New Zealand then I can supply.
Jan 01, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Can I use lucas oil white lithium in my stand mixer
They do not use oil at all, they use food grade grease. Any oil that is dripping out is the liquids separating out from the solids in the grease. You either need to open it up and stir the grease u again or remove the old grease completely and repack it with new stuff.
Nov 29, 2014 | KitchenAid Kitchen Aid K45SSWH Classic...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Nov 02, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
No sticker/model number on the bottom of my stand mixer and am missing the paddle attachment and dough hook.
Since you have not given a make...I'll take a stab in the dark and bet you have a kitchen aid...simply because you mentioned the dough hook. Kitchen aid has 14 models of stand mixers. You can match yours up and look at available accessories at www.kitchenaid.com
Sep 01, 2009 | Food Mixers
Kitchen Aid Mixer has a sound but it doesn't have power to mix
Hi. Goto www.mendingshed.com and download the free Kitchenaid Service Manual.
You may have overloaded the mixer with bread or cookie dough, causing internal damage to the gears.
If you plan to do the repair yourself, you might also consider removing the old grease and oil. Remove, clean and regrease the planetary gear assembly as well. This will add years of life to your mixer.
Regrease with Chevron FM ALC EP-2 product.
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 27, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
431 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
