Question about Dell Photo 964 All-In-One InkJet Printer
Distorted printed documents
I have a Dell Photo All in One 964 printer. It is just over a year old. I primarily use it for printing documents from Word, Excel, internet sites - for home computer. It has recently begun to print documents with every 3rd or 4th lines printed split and slanted horizontally. Doesn't look very good for my son's school papers. Somewhat unreadable for those lines. Any suggestions?
Also, the printer makes an awful noise as it begins to feed the paper.
    Genius:
  • 2,035 Answers
Try this steps first and these steps first :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Feb 17, 2009
  • Anand Kumar
    Anand Kumar Feb 17, 2009
    And then try to clean the cartridges :
    # Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
    # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
    # Continue doing this until it looks clean.
    # Then dab the cartridge on the towel to make sure the ink is flowing.
    # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    # Reinstall the cartridges, making sure you snap them correctly into the printer.
I have a dell 964 all-in-one and i have faxes in memory that i want to print i want to print them. how do i do it? thank you
Click on the link below and select your language to view the Dell 964 owners manual, inside the manual will show you how to print stored documents from memory:
http://support.dell.com/support/edocs/systems/PRN964/?c=us&l=en&s=gen
Dec 09, 2010 | Dell Photo 964 All-In-One InkJet Printer
Printer won't finish 2-sided document
Uninstall Dell All in One Center. Download the laters drivers form http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_PHT_964&os=WW1&osl=en&catid=&impid=
it will fix your problem.
remember to choose the correct Operating System.
Jul 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
How to get the all in one fax / copier /printer to stop printing a report after each incoming and out going fax. It waistes ink and paper.
1 Click Start Programs or All ProgramsDell PrintersDell Photo AIO Printer
964
Dell All-In-One Center.
2 From the Dell All-In-One Center, click the Maintain/Troubleshoot tab, and then click
Display the Printer Setup Utility.
Printer Setup Utility Tabs
On this tab: You can:
Send • Enter your name and fax number.
• Select a maximum send speed and a print quality for outgoing faxes.
• Choose whether to scan the entire document before dialing the number.
• Choose whether to use error correction.
• Select when to print a fax usage report.
• Select when to print a fax activity report.
this information is from the manual found here
http://support.dell.com/support/edocs/systems/PRN964/en/om/om_en.pdf
I hope this helps
Mar 12, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell 964 All in one printer
The cost of getting the reader repaired would far outweigh the cost of replacing the printer. Your best bet would be to get a card reader that can hook up to your computer and print it out like you would any document.
Feb 26, 2009 | Dell Photo 964 All-In-One InkJet Printer
Bought it a month ago printer status says ready but jump to file willnot print
You need to ensure your document isn't set to print to a windows document printer. Change it to your defaut printer and it'll work.
rstrg2
Aug 23, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 964
i refill my ink, it dases not recognice it and when attempting to ptint document it open a window with erroe#1203 ,please help
Aug 18, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 964
run a print head clean and alignment from computer print manager
Aug 14, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell 964 all in one printer
During the photo printing wizard, in printing options window, choose the printing preferences button. Once you are there, choose the maintenience tab located on the top of the screen. Choose the clean print cartridges button. Hope it works!
May 21, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 964 - unsupported cartridge
How is it plugged first of all, did you set it up as a dell printer in add printer? try adding it as a HP printer since they are HP printers with the Dell name.
Oct 04, 2007 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo All in One Printer 964
Try printing a windows test page from the driver software, START-SETTINGS_PRINTERS-DELL964- properties,,etc. If the test page prints with color then I believe that your driver is set to print in greyscale. If you can't find that option in the driver you might try to re-install the driver from your original cd.
Aug 28, 2007 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
78 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
