Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile water filter housing leaks
GE profile model PSS26GRE SS. I have the filter removed and the "bypass plug" installed because we run treated water to the frig (no need for the filter and it just slows the flow). I have a leak from the filter unit with the plug installed. The plug installs over a cone-shaped stucture on the filter housing that has 3 O-rings. The plug slowly fills (hours) and then water drips onto the top shelf of the frig. I tried replacing the O-rings with ones from Lowe's but it leaks faster. Is it leaking from somewhere else? Are the O-rings a special dimension that I have to get from GE? The parts diagram only shows the entire filter housing, as if I can't get the O-rings by themselves.
  • 172 Answers
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Feb 17, 2009
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
GE Fridge - The water filter bypass plug is stuck
Should just take a quarter turn CCW to remove. You may loose a few drips of water, but the water shuts off automatically when the plug or a filter is removed. A wrench should not be needed to do this.
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I just installed a new MSWF water filter cartridge on my GE Profile refrigerator. After pushing the reset button, there is no water flow at all. I can hear the pump humming. I tried removing and...
Tried new filter. Thought water line frozen. Problem solved by bypassing the water filter. Now that I'm working without filter I will troubleshoot the filter receptacle.
May 04, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
GE Profile Refrigerator leaks
How long have the filter been inside the refrigerator, if 3-6 months that is usually the life of the filter and it is time for replacing, it is common for the filter to leak once it has reach it life expectency
Dec 13, 2009 | GE Profile PSW26P Stainless Steel Side by...
Profile side by side refrigerator,model #GSC23LSRC SS
If you can get to the line in queston take it loose and blow it out, make sure that the filter has been taken loose prior to doing this
Aug 28, 2009 | GE DBSR453EBWW Electric Dryer
I have a water softner in my house do I need the smart water filter on the refrigerator GE model PSS26NGSA GE PROFILE. I use the filter bypass plug but there is no water running thru the dispensor. Do I...
If your using the correct bypass plug which came with the refrigerator , the water dispensor should still work . Make sure the plug is very snuggly , tight in place .
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Have you tried a new GE filter? Use only GE brand. You can purchase a bypass plug from GE parts 800-626-2002
Jun 23, 2008 | GE DBSR453EBWW Electric Dryer
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,037 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
