Question about Protron PLTV-32 Television
When tv is on the screen has a vertical blue bar in the center of the screen
  • 6 more comments
  • greenoaks316 Feb 17, 2009
    there is no noise
    the tv i only 3 years old and is a protron 32" lcd-tv
    my protron 32" lcd tv has a blue vertical bar in the middle of the screen when tv is on please help
    please define tv panel and do you know the approximate cost? thanks for assisting
    protron 32" lcd tv has blue vertical wide line in center of screen when viewing tv
    32" protron lcd tv has wide blue vertical line in center of screen when viewing tv
    32" protron lcd tv (not plasma) has wide blue vertical line in center of screen when viewing tv
    degaussing a coil on a lcd tv - how is this done
  • 6,784 Answers
This may be some kind of local interference form a close by device. Check around the set to locate anything that may be causing some sort of interference with this LCD set. I would also reset all control settings to the default setting and if the problem persist, you may have a main logic board issue.
Posted on Feb 17, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
May I offer an alternative suspect?
To my understanding a Protron PLTV-32 is an LCD HD Ready TV unit. A common problem with this particular model is the power supply adapter. Insufficient power delivery can be manifested in many ways including one as you have just described.
Adapter specs:
  • Proton PLTV-32 LCD TV
  • power supply M/N LU32A1A3
  • Input: 100-240V 50-60Hz 3.0A Max.
  • Output: +24v-6A---12V-3A.
  • Ac adapter connector to the flat Tv screen needs: 4 Pin Din Plug.
Pls check likewise if the blower/fan in the adapter is working. It may be a heat related issue. Alternately, it can be a capacitor in the primary side of the power supply.
Proposed course of action would be to use a voltmeter (DVM/VOM) to check for the presence/absence of correct voltage at the 4 pin plug. It may be necessary to open the power supply for an ocular inspection. Capacitor would have physical faults when defective; blister, splits, oil leak, bits of brown paper, bulging to or bottom.
If you are considering a DIY (do-it-yourself), this would require familiarity with electronic circuitry and components, use of a DVM and a soldering iron as well as safe practices when working with electricity. It may also be to your advantage access to a Service Manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable with a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Good luck and thank you for using FixYa.
    Sergeant:
    Champion:
  • 289 Answers
Hi..the best solution to this problem is by
degaussing the coil.once you do this it will
solve your problem.
check it out..
thank u..
  • Hariharanath V Feb 17, 2009
    There are two types, a wand or coil type.
    Both work the same way.
    A bit of advise first though, if you wear a watch take it off before using the coil as they emit high levels of magnetism and could damage your watch.
    TURN THE TV OFF!!!!! and unplug it.
    Plug in the degauss coil.
    Put the coil to the centre of the TV screen.
    Press the red button on the coil (or any other activation device)
    The coil will start to hum, slowly move the coil in a circular motion whilst moving the coil slowly away stepping back from the tv.
    I think at a distance of approx 4 feet you can turn it off.
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
  • Anand Kumar
    Anand Kumar Feb 17, 2009
    Remove the input signal source from tv and check if still have blue line in the center ..
  • 744 Answers
Hi u have to go for a replacement of ur tv panel.....
  • Protron Master
  • 19,396 Answers
It can be the sustain board or the buffer, is this a plasma model;?
  • Ginko
    Ginko Feb 17, 2009
    If the TV is LCD the problem is either the lcd cable , or the video controller on lcd controller board.
    If this is a plasma then you need to test and eventually replace the lower buffer board and the ysus board.
    Brigadier General:
  • 8,619 Answers
Hi
Are you able to hear any noise as well. Switch off the TV for 15minutes .
  • Rylee Smith
    Rylee Smith Feb 17, 2009
    Are you facing this problem with both the cable box and Dvd both then the control board needs to be checkd for any burned components. If you are using RCA(three component cables) then try using HDMI cable.
    Please revert for any clarifications
    Thanks
    Rylee
4 Suggested Answers
Kindofcheap
  • 241 Answers
SOURCE: 42inch LG plasma TV
well if you could please give out the model nuumber thank you
Posted on Sep 10, 2008
praky16
  • 744 Answers
SOURCE: Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Posted on Jun 01, 2009
tvtek
  • 1284 Answers
SOURCE: Blue spot and vertical smudge in center of screen.
The problem is your light engine is failing. The part number for this is UX22201DR and is available for purchase with the following link. It runs $334 dollars and really is a part that needs to be replaced by a technician due to the complexity in tear down to remove it. Please take a few moments to rate my answer. Thanks...
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/UX22201DR/New.aspx
Posted on Nov 20, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
hi...
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Faint blue vertical bars on screen
What you see on your screen are retrace lines, it can happen for various reasons. Jut lower the screen voltage by adjusting the knob specified as "screen" on the LOT, this will disappear.
Jan 27, 2008 | Sharp 32R-S50 32" TV
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
Jan 06, 2008 | Televison & Video
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
SVA E2939FQU
Sure!!. TDA 78041 or Tda 78040 I can help you, let me know model number tv.
Feb 20, 2007 | SVA-USA E2939FQU TV
Protron PLTV-32 Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
