Question about Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue
DRYER RACK DOES NOT DRY CLOTHES
WHEN WE USE THE DRYER RACK IN OUR SAMSUNG DRYER THE DRYER OPERATES BUT SHUTS OFF WAY BEFORE CLOTHES ARE DRY.  IN FACT IT SEEMS THERE IS NO HEAT.  THE DRYER WORKS FINE WITHOUT THE DRYER RACK.
  • Anonymous Mar 22, 2014
    dryer runs cooling icon is staying on no heat to dry clothes checked vents and hoses for clogs all clear
  • Anonymous Mar 30, 2014
    dryer just stopped in the middle of drying a load of clothes, all lights on the panel are working the tub wont turn.
  • 35 Answers
Possibly your moisture sensor thinks that the clothes are already dry when you use the rack because it doesn't sense the moisture. Try to run the dryer on a timed cycle or a cycle that runs without the moisture sensor. Check for heat immediately after starting in this cycle to see if it could be amoisture sensor problem. Techs for the dryer may be able to give you a different solution but I would try a different or correct type of cycle for using this rack.
Posted on Sep 21, 2010
  • 686 Answers
Try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Posted on Feb 17, 2009
When put in sensor dry setting, dryer shuts off in a few minutes before clothes are dry
I'd suggest the dryer "sensor thinks" the clothes are dry, or uses a diffenernt standard, or it's bad. I'd revert to the tried and true method of "time".
Mar 05, 2015 | Amana NED7200TW Electric Dryer
Why dryer shuts off too early on auto
The sensor detects the moisture content of the clothes, If the clothing is packed tightly some of the clothes in the middle of the pile might not dry completely, if the clothes on the outside near the drum have low enough moisture. If you have a position on the control for dryer clothes or a more dry position try using that or use timed dry.
Aug 01, 2014 | Whirlpool Dryers
Displays code E4A , clothes will not dry
Hi Alicia Rosa - Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Nov 25, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer displaying code E4A, clothes are not drying
Hello - Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Nov 25, 2012 | Frigidaire Dryers
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Mar 16, 2009 | Dryers
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
DLE5932W - Not shutting off when clothes are dry - keeps running
You have a computer control board problem and needs to be replaced.  The internal program has a problem and won't time down properly.
Jun 24, 2008 | LG DLE5932W Electric Dryer
Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue Logo
1,139 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
