Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Tub gets off balance during spin cycle
This is a wirlpool model LSR8233eq0. I suspect this could be the tub block.
  • 25 Answers
Also,shorten front legs,lean washer forward,and reset back legs.level.
Posted on Feb 18, 2009
Machine goes out of balance & vibrates on spin cycle
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 19, 2015 | Washing Machines
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
By the way my advice is free cuz God is good!
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
I have a Samsung washer model number wf338aab/xaa my tub is off balance
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
Is off balance during the spin cycle mor often
I have a 10yr old Maytag Atlantis model MAV7258AWW. Here is how I solved my balance problem. It appeared that I had two problems. One was that it would not spin fast, the second was that it would spin off balance. To get the washer to spin fast like it should I had to open the lid then close it, re-engaging the spin cycle. I opened the top and watched the motor engage in the spin cycle. with the top open, I would open and close the lid activating the lid switch. Each time I closed the lid I noticed that the motor would move a little bit more on its glides to tighten the belt. Sort of like a automatic adjuster. The motor is designed to pivot one way for the agitator the other way for spin. If the motor does not pivot correctly, the belt will not tighten and will slip. I removed the front panel, cleaned and lubed the pivot area. Now the motor glides on the pivots like it should. I ran the spin cycle and the motor slid all the way to one side like it should, the belt tightens and the spin cycle spins. Now that the spin cycle works, quess what?? The balance problem is fixed as well. It appears that the reason that the tub was going off balance was because the belt was slipping not spinning the tub at maxium speed as designed causing the off balance problem. The tub was not spinning fast enough causing the off balance problem. I have ran several loades in the washer and not a problem. I did replace the snubber, it was worn out but it still spun off balance. I hope this helps to all who have a balance problem.
Mar 02, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSR8233EQ0- The load is still wet after spin cycle
Inner tub loose or bearing or stem is bent. Check belt for oil or wear.
Oct 20, 2009 | Washing Machines
Check base mount springs, there are 3 from base to tub and 1 from tub to back bottom for counter balancing. If all are ok then you will have a skid plate problem. Best to call for help.
Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
161 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
