Question about Sony Playstation 3 (PS3) Console
PS3 NO Screen NO Ejecting of disc stuck in there. NO Controller.
Starts up when i turn it on and i hear the fan and the disc spin but not much of anything else. Return it or something i can fix?
Well my xbox 360 had the same problem after i went in to fix the unreadable disc error and i went back inside and opened it up and found out i forgot to put a wire in, im not sure if u opened urs, but maybe somehow a wire came loose
Posted on Feb 17, 2009
Ps3 freezing and disc wont read and skips
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
Take care.
I wish you good luck
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
The game got stuck inside,and It doesn't reject it. What I need to do to take it out ?
Ok please try the following to force eject your disc. Turn off the power at the back of the PS3. Press and hold the eject button. Turn the power back on at the back of the machine. The fan should start to spin very fast but your disc should also be ejected.
Hope this helps and thank you for using FixYa
Sep 05, 2010 | Sony Playstation 3 (PS3) Console
My ps3 stop playing my game disc
The most common reason for the game not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
You can also try the steps below. Its from PlayStation Forum:
well as cookies.
Take care.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Ps3 bluray will not load cd's, games, or dvd's
If console will not read any discs (dvd cd or bluray)
If you hear it spinning
1 Either the lasers is bad (replace laser)
2 drive board is bad, can be controller chip (send into sony or replace chip)
If you do not hear it spinning
1 spinner is bad (replace caddy assembly)
2 drive may be off track not completly loading the discs (might need to replace side tack or reattach v shaped bracket to side tracks)
3 Controller on board can be bad (same as above)
Aug 03, 2010 | Sony Playstation 3 (PS3) Console
Ps3 want read any disc what do i ned to do
2 spinner is bad
3 Or drive board is bad cant be controller chip (send into sony or replace chip)
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont read discs.................
Try to restore file system on your ps3.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
Disc not ejecting
Try the force eject (holding down the eject button for a few seconds until you see the blue light flash consistently) if that does not work try switching the power switch at the back ON while pressing the eject button at the same time causing the fans to blow at maximum rate & might eject your disc (Only let it blow for a few seconds on max power otherwise this could potentially burn up your graphics card!)
Nov 13, 2009 | Sony Playstation 3 (PS3) Console
Ps3 and sixaxis
Hello.
As for the PS3. When you put in a disc, listen for the disc to start spinning. If you do not hear that then the laser and/or the spindle have blown out. You will have to get your Blu-Ray player serviced by a pro or Sony. Sony may fix it for free. They know that the drives are failing. So call them first.
The controller is probably unfixable. Sony would consider that abuse and would not replace it. I would honestly go to a gaming store that takes trade in's and trade it in for a refurbished one. That would be your best bet.
I hope this helps! Good luck to you.
Jul 28, 2008 | Sony PlayStation 3 40GB System
Ps3 80 gig
Try getting a new AV Option, well actually first startup your PS3, startup your controller, and hit the center PS3 button, because those 2 options are only in the Main PS3 Option, which is accesed and closed through hitting the middle button on your controller. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
70 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
