Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Will not turn on
Plug vacuum in, and it will not turn on
  • 1 more comment
  • debhenson Mar 01, 2009
    My DC07 won't turn on either.
  • skuellsmopar Mar 10, 2009
    my vacuum will not turn on at all. I would love to know where the thermal shut off is
  • Philip Gaut May 11, 2010
    What make and model of vacuum is this? And what country are you in?
    Problem Solver:
  • 6 Answers
I read somewhere that they had a problem with the on-off power switches and maybe a recall? but i'm not sure?
Posted on Mar 03, 2009
How do I get the vacuum to turn on now?
Just to cover all bases, have you tried an outlet on another circuit? It sounds as though the vacuum (motor perhaps) shorted and tripped the breaker.
Nov 15, 2017 | Miele Vacuums
Won't turn on stop running in the middle of room.
Mine did the same thing. The electrical cord is loose where it plugs into the machine. When you pull the vacuum into the room it puts just enough strain on the cord to break the electrical connection. Push the plug on the cord firmly into the vacuum.
Sep 08, 2013 | Eureka 3276AZ Pet Lover Bagless Upright...
The vacuum was on when my son tripped the cord and one prong broke off in the outlet. We patched on another cord. It won't turn on tried other outlets. Can't find reset switch, is there one or did we...
Maybe you got the wires crossed between the two cords. Vacuums have polarized plugs and if wired imcorrectly can definitely cause the vacuum to not work. Try switching over.
In other words, consider current wires as A1/A2 and B1/B2. Disconnect, then connect A1 to B2 and A2 to B1.
vacuum===============A1 A2=======Plug
===============B1 B2=======Plug
Switch to
vacuum===============A1 B2=======Plug
===============B1 A2=======Plug
Try this and see what happens.
Jan 03, 2011 | Dyson DC14 All floors Bagless Upright...
My Eureka Altima Upright Vacuum Model 2996AVS Vacuum wont turn on. Any advice where to start? I would think it may be a fuse but do not know where it is on this vacuum.
Generally, on something with a cord and plug, the first thing I suspect is a bad spot in the cord where it connects to the plug. One way to check it is to turn the vacuum on, plug the plug into a good outlet that you have checked to make sure it works. If the vacuum doesn't come on, then grab the cord about a inch or two behind the plug and push it into the plug, so that if the wire is broken, it will touch enough to make the vacuum come on. If it does come on then you will need to replace the bad plug, If it does not come on, then I would suspect the ON/OFF switch. Best of luck
Mar 20, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuum won't turn on when plugged in and switch is turned on
The easy answer to this problem is you need a new cord. Any fit all 20 to 35 foot two wire cord will work. However, you will need to take disassemble the almost the entire vacuum to test the current cord to see if it is bad. There are a lot of pieces to take off to get to the inside of the vacuum where the cord enters from the back. You could also have a bad motor.
Nov 18, 2009 | Hoover U6311-930 Power Drive Bagged...
Will not turn on. Fully charged.
SOUNDS LIKE THE BATTERY IS SHOT AND WON'T TAKE A CHARGE.DOES THE CHARGER PLUG DIRECTLY INTO THE VACUUM.IF SO SEE IF IT COMES ON WITH THE CHARGER PLUGGED INTO IT.IF IT COMES ON THEN THE BATTERY IS NO GOOD.PLEASE LEAVE FEEDBACK
Mar 26, 2009 | Euro-Pro Shark Cordless Stick Vacuum...
My Eureka Whirlwind vacuum on-off switch won't turn off
the power switch is bad. go to your local hardware store and buy a new power switch and replace it.
Mar 23, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
111 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
