Question about Maytag MZD2766GES Side by Side Refrigerator
Fridge is warm ,freezer is fine .freezer on bottom .not a side by
Maytag model mbr1956hes,approx.1 yr. stainless steel.warm in fridge even after adjusting control.
  • Anonymous Feb 23, 2009
    The refrigerator is warm and the freezer is cold. When I took the panels off in the freezer comparment I was able to get to the evaporator coil. I found it covered in ice, I am melting the ice and suspect the defrost timer. But I am having a hard time locating a wiring diagram and finding the location of the defrost timer.
  • 218 Answers
SOURCE: error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Posted on Jul 25, 2008
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
  • 4 Answers
SOURCE: MAYTAG SIDE BY SIDE FRIDGE FREEZER STAINLESS STEEL
The problem will come back in about a week once the coils frost up again. This seems to be a common problem with these refrigerators. I had the same problem a while back. Sounds like your defrost board is dead. part number is 12002104. You can find it at searspartsdirect.com
Posted on Jun 28, 2009
  • 80 Answers
SOURCE: Fridge running hot!
One you can to try and extend the life of the fridge is to vacuum off the compressor and coils. They can be located either behind the toe grill on the bottom front or through an opening on the back of the fridge. It is natural for a fridge to blow warm air.
Posted on Aug 30, 2009
Testimonial: "I vacuum cleaned the coils and compressor. Everything seems OK. I know it is necessary for a fridge to give off heat; but it seemed excessive."
Freezer not cooling, but fridge works fine
In most cases the problem you are having is a defective start relay, overload and run capacitor. These parts can wear out or the symptons are caused by a defective fan motor. What is the correct model number? Sea Breeze
Sep 25, 2013 | Maytag MFF2557HES Stainless Steel French...
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so...
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
May 28, 2017 | Maytag MBR2562HES Stainless Steel Bottom...
I have a Maytag Stainless Steel Fridge side by side 10 month old, freezer works fine fridge warm as death! Freezing lower cold air vent between the two drawers. Model MSD 225 8AE SO1 Serial...
i couldn't look up your machine,maybe bad model number,i would call the factory,it's under waranty for the first year,you either left the door open or you have a defrost problem,let me know if you're gonna call the factory or if you want to fix it yourself,if you want to repair it let me know and check the model number inside the fridge section on the right hand wall up near the ceiling
Sep 22, 2010 | Refrigerators
My freezer is fine but fridge side is warm and no air blowing
SOUNDS LIKE THE FAN FROM THE FREEZER TO THE FRIDGE TAKE OFF THE COVER TO SEE IF ITS WORKING
Sep 02, 2009 | Maytag 26 cu. ft. Wide-By-Side...
Fridge running hot!
Aug 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Warm Fridge
SOUNDS LIKE U MAY HAVE A BAD DEFROST TIMER, CAUSING THE COIL TO ICE UP, AN SINCE THE COIL ICES UP THERE IS NO AIR PASSING TRU TO KEEP THE FREEZER COLD AN THE FRIDGE COOLER, THE FAN MAY BE WORKING BUT IS NOT MOVING ANY AIRE TRU IT, BECAUSE THE BLOCKEAGE
May 28, 2009 | Maytag MB2262H Stainless Steel Bottom...
Fridge is warm even when i adjust temp. control.freezer is good.
Feb 17, 2009 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
127 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
