Question about Kenmore Microwave Ovens
UNIT POWERS OFF AND DISPLAYS "F-9"
My unit is a Kenmore Elite ULTRA WAVE Microvave Hood Combintation.
Model # 721.80869400
1200W
Problem:
No matter which power level is used, the unit runs for about 3-5 seconds, then powers off with "F-9" on the display.
I also tried using the Auto Cook Function, but after several secondsthe unit powered down and displayed "F-9"
Can anyone help? Thanx.
    Sergeant:
    Habit-Forming:
  • 194 Answers
An inverter failure. This can sometimes by caused by a power surge or glitch through the electrical lines. You can sometimes clear this fault by completely unplugging the microwave for 1 minute. Plug it back in and see if the fault code returns. If it does, then you have an internal component failure that will need to be serviced by a technician. Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair
Posted on Aug 03, 2017
  • 4 Answers
SOURCE: Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Posted on Nov 23, 2007
reg501
  • 413 Answers
SOURCE: Kenmore ultra elite microwave hood combination
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Note: This 'technology' may come in other flavors as well
Posted on Jun 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: f9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
Posted on May 20, 2009
SOURCE: I have an error code
I would like to repair the kenmore mocrowave myself, it has the error code f-9. Do I need to let the micrwave sit for a wile so the hi voltage can disipate from the inverter or magetron
Posted on Aug 07, 2009
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
Aug 15, 2009 | Goldstar MV-1515 Microwave Oven
9Fp and microwave cuts off
F-9 means the inverter board has failed. A bad magnatron can also cause this code. Recommend replace the Mag. and inverter board.
Feb 27, 2009 | Kenmore 62622 Microwave Oven
F-9 Error code
The F9 error code indicates a failed inverter. If resetting the unit does not help you will need to have the inverter & harness checked.
http://media.fotki.com/1_p,wbgdfgsrsttwqwbxgtqsskgwtqkq,vi/kgdfkfrkkxkfdtftrfb/1/1303472/5961857/image45625img-or.jpg
A microwave radiation leakage test must be performed on the unit following any internal component repair.
It does not ALWAYS indicate a inverter control board problem however in other brands/models.
LG's service manual (for an example) suggests the f-9 code could be due to line voltage, magnetron, inverter module, "Relay2", or a loose connection between door/magnetron/control pcb.
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case.
For example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possibilities.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 17, 2009 | Kenmore 80809 Microwave Oven
F9 Error
You can find exploded views and order parts by entering your model number at the Sears parts site.
Dec 06, 2008 | Microwave Ovens
The Magnatron is a major job and unless you first looked into or had the Inverter Board replaced, you are wasting your time. 90% of the F-9 problems fall into the Inverter solution, Try that 1st, it worked for us!! My Micro now works GREAT!!
Sep 09, 2008 | Kenmore 62622 Microwave Oven
Jan 19, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
71 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
