Question about TurboChef TORNADO Electric Oven
How can I clean the catalytic converter?
How can I get to the catalytic converter of the Tornado Oven for cleaning?. THANK YOU
  • 125 Answers
Hello. Do this when cool of course, in the back of the cook cavity, near the bottom is a plate, remove the screws holding it on, and work out of place, the converter is up inside of that area, and may be a couple additional screws to remove in that same area, that hold it in there. I just sits up in there and needs to be slowly worked out, once out, rinse off, do not use cleaners, etc,, or you will remove the catalyst, and then you need a new one, reverse assembly.
Posted on Feb 22, 2009
Turbochef Tornado EC cooling fan ALWAYS runs at full speed
What jim said is right. plus clean the front vent. take off bottom front panel and clean all the little round holes. also if its dirty inside everything runs hotter(which makes the EC get warm faster) and dirt gets on the little wire(it's about 4" long coming from the main 40 pin connector0 that monitors the EC temp(clean it). sometimes the fan starts to get weak and doesn't cool properly. also, unplug oven, take side panel off and clean it as well. there are vents on it that get clogged. while it's unplugged clean the inside. I use a paint brush and shop van. just be careful not to hit wires or knock wires off. this will all help a bit but that fan will still run a lot anyway.
Apr 21, 2014 | TurboChef TORNADO Electric Oven
Smoke comes out of unit
If it's coming from inside the oven ,clean underneath the cooking stone, if it's coming from the side panel it's probably the mag transformer.
Dec 10, 2013 | TurboChef TORNADO Electric Oven
Can u cook air fried chips in the turbo.tornado oven
Yes any thing that is not greasy as it will block the catalytic converter
Jun 02, 2012 | TurboChef TORNADO Electric Oven
Hi i have turbochef speed oven in subway and on display show F6 ec Temp . what is problem
F6 faults occured when temperature reached to 150 degree faharanite in the electrical compartment.
1. Clean the dust in the electrical compartment.
2. There is an temperature sensor on the controle board which gets dirty and throw wrong values.Clean it and then try.
3. Check the exaust fan in the top rear location is working properly.
4.Check for proper air ventillation.
Apr 15, 2011 | TurboChef TORNADO Electric Oven
Oven is displayin f1 blower and f7 thermostat, blower is not running?
Usually these happen when IO board is about to go. I have experience this . Clean the board and try to plug in wire connector back to the board. If it eke minarets or creates any new error code then you definitely need io board
Feb 11, 2011 | TurboChef TORNADO Electric Oven
I have both a tornado and a C3. I am getting a F2
for the f2 low temp verify the high-limit thermostat is not tripped. inspect the mags, make sure they are not loose. Also try inspecting the ir element washer look for corrosion or signs of arching. Is your wave cover damaged or missing. Sorry to say this generally is a factory trained fix because its usually because of an rf leak
Oct 09, 2009 | TurboChef TORNADO Electric Oven
When I push the on button after the oven is in "Snooze" mode, the oven starts cooling down instead of heating up . Then when I push the on button again, the screen comes up and says oven ready.
Pushing the Back touch pad will give Snooze option, push it again and the Oven Off comes up. From there you can leave it off to cool down and clean, or push the bottom right pad to turn on,
Jul 16, 2009 | TurboChef TORNADO Electric Oven
Turbo chef oven F6 ec code
Hello. There is a temperature sensor built into the control board, and the temp in that area, is getting too hot. On the back of the unit, right top, there is a cooling fan that comes on at a certain temperature, if the intake is clogged, you will get this error, clean the intake. Inside the unit may be so dirty, it may require cleaning as well. The fan itself could be bad, and does not run, then it will need replacement.
Hope that helps, and thank you.
Feb 04, 2009 | TurboChef TORNADO Electric Oven
How do I turn off the oven light
go to and look up the owners manual for your product
Jan 16, 2009 | TurboChef TORNADO Electric Oven
Cleaning better than self-cleaning
What you have read is correct, the catalytic lining can be damaged by corrosive sprays. It should be safe to use 'Easy Off ' on glass though.
The standard Auto clean cycle is the best method of cleaning that i know of.
Nov 29, 2008 | GE JTP86 Electric Double Oven
TurboChef TORNADO Electric Oven Logo
658 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
