Question about Hunter CareFree Plus 33222 Humidifier
How do I clean Hunter Humidifier # 34407 Nite Glo
I get light brown water after a few uses.Why is this? How do I clean the filter. I have had it awhile and I don't kow if it should be silver or white like it is now. and How to clean this.
  • 1 more comment
  • MARYANNE MASTRO Feb 17, 2009
    thanks dragonthatk now how do I tell if I have a washable filter ? wash it and see if it falls apart? It is silver.
    When I bought this years ago at a well known store, it came with a filter in it, sooo I am assuming it is a washable filter...
  • MARYANNE MASTRO Feb 18, 2009
    Thank You for being here. You rock!
  • 547 Answers
The brown stuff is dust dirt unless you smoke then its that if you have washabule filter then wash it if not you must buy replacement filter thank you for useing fixya
Posted on Feb 17, 2009
  • albert getty
    albert getty Feb 17, 2009
    when you bought it did you buy a washable filter? if not it is not a washable one and you need to buy one it cost about 35 dollars you can pick it up where thay sell the unit thank you for useing fixya
  • albert getty
    no that is a replaceable one the washable one needs to be bought seperate
How to clean a filter for humidifier hunter 33201
just remove it, then rinse it in warm soapy water, let it dry and then replace!
Nov 07, 2009 | Hunter 33201 Humidifier
How do I clean my hunter humidifier 33201? the filter blocks have white calcium? built up. I have sick kids and want it to be clean and running properly.
Soak the filters in a solution of 8 oz of white vinegar per gallon of water for about 20 minutes once per week and rinse well.
Better yet, do this once every 2 weeks, and on the off weeks soak the filters in a beach and water solution (rinse well) to keep the mold and bacteria growth from becoming a problem. I also add about a teaspoon of vinegar or a teaspoon of bleach (one or the other, not both at the same time) to the water when I fill the tank.
That helps keep the calcium scale from forming and it keeps the unit itself MUCH cleaner.
Oct 13, 2009 | Hunter 33201 Humidifier
Hunter Humidifier #33222
From The Hunter Manual
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes.
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOUR HUMIDIFIER to continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Jan 16, 2009 | Hunter CareFree Plus 33222 Humidifier
How do I clean Hunter Humidifier #33222 ?
From The Hunter 3322 manual.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
Jan 04, 2009 | Hunter CareFree Plus 33222 Humidifier
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
Dec 18, 2008 | Hunter CareFree Plus 33222 Humidifier
Water for humidifier
Distilled or bottled is best. I will help prevent build up internally. Steve
Dec 13, 2008 | Hunter Humidifiers
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
Hunter CareFree Plus 33222 Humidifier Logo
1,835 people viewed this question
Top Hunter Humidifiers Experts
Bargain Box
Bargain Box
Stephen
Vernon Taylor
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
