Question about Cakewalk Music Creator 4
MY MIDI NOR SIGMA TEL HAS SOUND OUTPUT
TRYING TO HOOK UP A KEYBOARD AND DRUMS THROUGH MIDI
  • Anonymous Feb 28, 2009
    you need to get a new sound card with midi ports.
  • 22 Answers
Signma Tel is notoriously bad for recording. It often doesn't work. But try changing your driver mode and then running the wave profiler. restart everything and make sure that your sound card is chosen under playback timing master and recordi timing master so that it is the chosen card. UNLESS- the keyboard has it's own sound card or interface built in, then its a different thing. You'll have to find out what kind of drivers THAT card uses and do same thing choosing that as card with correct drivers. Also check MIDI devices and make sure its in there. U might wanna email tech cuz this is a little more complicated than a regular set up
Posted on Mar 05, 2009
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
Need to hook my midi keyboard up to my dell desktop
audio on pc green blue and pink.green is out go to speakers. i think blue is input where your keyboard connects. pink is for microphone. you will need a cable with red and white rca type plugs to connect to keyboard the other end has one mini plug to go to blue or input on pc.
Aug 20, 2009 | Computers & Internet
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Apr 23, 2009 | Music
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Drums for MIDI track to not work
I haven't ever used this program but it sounds like you have your MIDI channel assigned to the wrong number. The default MIDI channel for drums is channel 10. Assign the track you are trying to play drums from to channel 10 in your program.
Jan 18, 2009 | Sony Acid Music Studio 7 Full Version for...
I get Midi Output but no Midi Input
Think you need to associate a player driver to the program. Try meida player as proxy driver
Jan 04, 2018 | Computers & Internet
Getting midi to register
Your question is very confusing. Try rephrasing it. You should try drawing a diagram with this and uploading it to your question to better explain yourself. If you can't upload it (I know I can through the answer, but I'm not so sure about the question) you can e-mail it to me. My address is johnkennick@yahoo.com , if not just put some more detail into the question and try rephrasing it. I'm not really sure about the details of your system.
Mar 12, 2008 | Tascam US-122 USB Audio/MIDI Interface...
MIDI hookup
The midi port looks like the bottom one in the picture:
http://www.e-tech.nu/images/sound_connectors.jpg
You need a cable from the keyboard midi (din connector) to the DB-15 on the sound card/mainboard. If you dont have a 15 pin midi/game connector you could buy a soundcard with midi onboard or a usb midi port like the:
http://www.zzounds.com/cat--USB-MIDI-Interfaces--2434
Jan 11, 2008 | Car Audio & Video
Cakewalk Music Creator 4 Logo
251 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
