Question about Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Thin thread from top to bottom on left side of screen.
There is a thin line appearing from top to bottom on left side of screen. I had the cable people out and they said there is aproblem with the TV. Sears will diagnose the problem for 95.00 and also charge for the repair. The tv is 17 months old.
    Problem Solver:
  • 10 Answers
Before rushing to Services, please do the 'INITIAL RESET' or 'FACTORY SETTINGS' or 'ALL RESET'.
Procedure is MENU/HOME/ WEGA GATE-> SETTINGS-> SET UP -> FACTORY SETTINGS/RESET.
Posted on Jun 22, 2009
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Thin and wide white lines on screen
Yes, your screen most likely is going bad, the only other reason for lines and distortion is a loose data cable that runs up the back of the lcd panel on the left side. For the touchpad, go to the control panel > Mouse > look at the top of the window and look for the device properties. open this tab and look for your touchpad listed. Highlight it and click on the settings button. Go through these settings and make sure that tapping is enabled. Even if it is, you may consider updating the drivers for the touchpad.
Jan 18, 2010 | Compaq NC8000 Notebook
Top to Bottom gray line on left side of Copied Page
hello
does the grey line appear if you scan true the "upper" scanner.(set paper on top of printer and sscan it that way)? you should also clean the smal slim glass that is at the side of the big scanner glass.
also try to remove all cartridges and tilt them side to side several times. then put them back and test your printer.
Jul 02, 2009 | HP LaserJet 2840 Printer
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
Thin Green line from top to bottom of screen
Usually the case with this issue is the LCD panel itself. After a certain long period of time, some LCD panels just bug out and stop working. ( not sure why, possibly the way they were assembled and manufactured. For instance the LCD Panel has 8 connectors ((top)) and 3 connectors ((left)) (((Depends on model)))that attach to the main board of the LCD Panel, and on many occasions the thin lines wear and cut and therefore loosing part of your screen. If i explain further how it works i can write you a good explanation, just message me. That is the issue or the Cable connector from the Video Card to the LCD Panel is faulty. Try replacing that or the line will stay there for a long while then eventually your LCD display will begin to show more lines and eventualy Nebula itself. ( unusable )
You can also try repairing the LCD, in some rare cases the only problem when the line shows up is because of the video genesis card inside the FPD. try swapping that out with a known good one and perhaps that will work otherwise eventually the monitor will begin to stop working over time.
Jul 02, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Thin Red Line on LCD TV
I had a similar problem with my LCD screen TV, and to my dismay, my warranty just ran out. A thin red line began to appear on the right side of the screen, and since many online and expert sources pretty much say replace the expensive LCD screen or get a professional to fix it (in which I suspect to be a business plot to get people to go to pricey experts), I decided to look for other possible alternatives.
Here is some tips/solutions I was given (and it worked! at least for me):
1) Turn off the LCD and unplug the power source and let it rest for 5-10 minutes. Turn it back on and see if it disappears or improve. (This is the one I used.)
2) While turned off, try jiggling gently all chords connected to the TV (cables, power chords, etc.); you could even try unplugging and replugging the chords/cables. Turn the TV back on and see if the red line disappeared or improve. (This is the one I heard worked for others.)
If the above doesn't work then I'm afraid you do have a bad panel on your screen and will need to call in the experts or get a new TV. I hope this will help. Best Wishes.
Apr 01, 2008 | Televison & Video
Horizontal lines on Screen
here's something you can try...remove the back and notice that there are ribbon cables (FRAGILE!) on the right and left side...alot of times these cables develope bad connections and cause the lines you see...other times the panel will be suspect. Removing these ribbon cables and reseating them have helped me determine in the past if it is a bad connection...or a bad panel
Jan 09, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Thin bright red vertical line from top to bottom of screen
that is the screen burned out. if still have a warranty return to company and get a return/exchange.
Oct 26, 2017 | Sceptre X7G-Naga 17" LCD Monitor
Sony BRAVIA KDL-40W3000 40 in. LCD HDTV Logo
422 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
