Tighting the belt
Can anyone help?I recently changed the drive belt.It was bad.But the new one seems loose.Its the same size.Is this normal.Is there a way of tensioning the belt?
  • ktparfitt Feb 19, 2009
    Thanks this was very helpful.
    Genius:
  • 1,075 Answers
Yes there is and its quite simple.num1take a good look and find the two pullys that are most apart pull the moter out towards the front of the machine ,before you tighten make sure the tention is no more than 14 ml.tighten .problem solved.adrian
Posted on Feb 17, 2009
John Deere lt155 traction drive belt adjustment
http://www.instructables.com/id/How-to-change-the-traction-belt-on-a-John-Deere-LT/the link shows the routing and idler spring either wrong size belt -inserted wrong or broken spring idler pulley
Sep 11, 2016 | John Deere Garden
2007 Hyundai Accent revs up in idle. Normal?
Ask your Mechanic it sound like the TPS could be going bad.
Aug 18, 2013 | Cars & Trucks
How do you fit a new drive belt to a rockworth compressor because there doesn't seem to be ant adjustment
if this is a small compressor say 2 hp you leave everything alone make sure you have the right size belt and stretch it on like a rubber band.. The belt will be quite tight but thats the way they come. If you are concerned that the new belt is too tight or too loose mark the position of you motor with a felt pen remove the belt and move the motor forwards or backwards a small amount in line with your marks, then refit the belt. The main thing is that the motor shaft stays parrallel or close to it with the drive shaft of your pump.
Jan 16, 2013 | Air Tools & Compressors
How to tighten serpentine belt for 2003 Monte Carlo 3.8L
the belt is self adjusted by a spring loaded automatic belt tensioner, if the belt is noisy or seems loose either the belt size is wrong (if it was replaced recently) or the tensioner is defective or one of the belt idler pulleys is defective.
May 27, 2010 | 2003 Chevrolet Monte Carlo
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
Sep 30, 2009 | Tools & Hardware - Others
How to change the belt on 5kg hoover washing
you have to re alliegn tha motor
Jul 12, 2009 | Washing Machines
How do you tighten PTO belt?
If the belt is loose it probably needs replaced or has jumped out of one of the pulley or belt guards allowing it to be sloppy. Belts get stretched in many different ways, tall grass, grass getting in the pulley, or they just plain stretch. First though, check to be sure the belt hasn't jumped out of it's normal runway.
Jun 23, 2009 | Ariens 34 In. Zoom Series Riding Mower
96 Geo Tracker Belt Removal Problem
it has more than one bolt.
loosen them all.
May 08, 2009 | 1996 Geo Tracker 2 Door
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
