Question about Belkin (F5D5231-4) Router
Cannot connect other devices to my router
I have a Belkin Wireless N router and it is hooked to my pc. It allows my PS3 to work fine but it won't let me connect my IPod touch, a laptop, or and IPhone. I have set up a password and it keeps saying it's incorrect but it's not. I have also tried to reset the router. And I have tried the encryption code, none of it works.
    Problem Solver:
  • 6 Answers
You reset it to open, no encryption and it still didn't work? HMMM. You are able to get your PS3 online? but can't connect your laptop and desktop? Are you hard wiring the desktop to the router? or are you trying to connect it wirelessly? If you are configuring your router with either the laptop or desktop, make sure the IP settings on your connection manager are set to the correct domain under Local Area Connection Properties, like 192.168.1.226, or something similar. Login to the router with your admin credentials. Make sure in your configuration (as instructed in your manual) that you have the router time set correctly so the lease time for your devices aren't expired. Apply settings. After exiting your router configuration screen, go back to your connections manager, either wireless connection, or ethernet adapter in your network connections folder, and under the General tab of the Local Area Connection Properties, change the properties of your TCP/IP client back to "Obtain an IP Address Automatically." Click "Close" and your computer should show "Connected."
Posted on Feb 17, 2009
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
I installed a Belkin broadcast router and my computer won't hook up to internet. My other computers (like the one I'm relaying this message) does fine. Downloaded D-link 520 drivers to a...
Go to my computer control panel network connections and see if the setup for networking is correct DHCP should work most of the time. Check the device manager and see if your nic is properly recognized. If not you might need to install drivers for the card.
mycomputer - control panel
mycomputer - view system information - hardware - device manager
Also, sign onto your router and see if the router recognizes the computer.
It should tell you how to do this in the routers manual.
May 09, 2011 | D-Link DWL-520 Wireless PCI Wi-Fi...
I have Belkin N150 Wireless Router installed. I can connect my laptop to it. When I tried my PS3 and I pod Touch and enter the same password but still it can't connect..guys, help me please..tnx
You have to allow these device to connect via MAC address ( Media Access Control) or set an IP.
This is done in the router. Check your router instructions for game settings.
Setting the router firewall game allowance or device is possibly where you are have an issue.
Jul 02, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How do i connect ps3 to belkin adsl2 modem with high speed wireless g router ? We have just changed our old belkin (cut out every time the phone rang) for this model and its working 10 times better with...
Network status can be checked in PS3 settings - it says whether the PS3 is connected to the network or not. If you see that it is OK, then you can check the router - it usually lists attached devices, also enable UPnP option if it is not ON yet.
If you have a problem with PS3 in wireless mode - try to connect it to the router with a Ethernet cable (configure PS3 network settings correspondingly) - if it works this way the problem most likely in wifi configuration either on the router or the PS3 side.
I hope this can help
Oct 05, 2009 | Belkin Computers & Internet
My belkin router won;t connect to my laptop, wii, ds or dsi
Did all these devices use wireless? Or were they plugged into it?
The router may have reset itself so you might have to sign in to the router and setup the wireless again.
The PC that is hooked via ethernet, did it use the router wirelessly at all?
Try signing into the router and check the wireless security key settings etc. Reset it if you have to type in a new key and try testing the settings with one of your wireless devices to see if it works. Remember to have the device on the same key/index/channel and the same security type as is set on the router.
Apr 12, 2009 | Belkin Computers & Internet
Belkin G Wireless Router Connection problem
Sounds like a faulty router or issue with the firmware if it is unaccesible, your best solution is to factory reset the device and try again.
Regards,
Kris
Mar 17, 2009 | Belkin (F5D7230-4) Router (587009)
Ps3 problem
- Physically connect the PS 3 to the Belkin router on one of the LAN connection
- Check the connection of the PS3 (if not connecting through)
- Contact your PS 3 manufacturer to gather the ports of the PS 3 and open it on the port forwarding of your router configuration page.
Note: you'll needing to allow the ports of your PS3 and IP address to the Belkin router.
Mar 07, 2009 | Belkin F5D7330 802.11g/b Wireless Adapter
Connection lasts about 5 minutes
Basically if you do a connection test on the ps3 and it comes back as NAT3 then you will have problems. You need to forward some of the ports of your modem to get to NAT2. You will need to assign static ip addresses to your PS3s so that you can set up port forwarding
You may have interference from a nearby cordless phone (keep these away from router), could be interference from neighbor, try changing channel you use on wireless router.
Some people have reported success just by turning off SSID broadcast in the wireless router.
PLAYSTATION®Network Guide
Jan 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Unable to use other wireless devices with belkin f5d7630 router
Make sure that the wireless devices which you want to connect has the faciltity of accepting the security passwords of the router
Dec 29, 2008 | Belkin (F5D7230-4) Router (587009)
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
Belkin (F5D5231-4) Router Logo
758 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
