Question about Maytag Neptune MDG5500AW Gas Dryer
Gas dryer burner won't stay lit on maytag dryer
The gas burner ignites but it will not stay lit and therefore dryer is not heating up???? Any ideas on what it is??
  • 5locketts Apr 30, 2009
    I have the same issue. Gas ignites and blows heat into rolling drum, but then goes out after 15 seconds. How can you tell if it's the Radiant Sensor or weak gas valve coil
  • Anonymous Mar 30, 2014
    Burner not staying on
  • 547 Answers
Thermo cupple need's to be replaced
Posted on Feb 17, 2009
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
Malta dryer burner won't stay lit
usually a clogged vent or I've seem a coil go bad that allows it to light once but not the second time in the cycle
Feb 01, 2012 | Maytag Dryers
Maytag Model # LDG510 - Dryer burner will not stay lit. Electric igniter glows but will not lite gas. Igniter cycles on and off.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Nov 10, 2010 | Maytag Dryers
Gas burner won't stay lit
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 10, 2010 | Dryers
Gas maytag dryer not heating up
check the thermal fuse in the dryer vent duct to be open,then if not the flame eye" radiant sensor" or the high-limit thermostat both on the burner tube if the sensor doesn't see(sense) a flame the gas valve will stay shut,then check the gas valve coils,both the BOOST and SECONDARY coil valves on the gas valve body as these can open up and not gas into the burner
May 04, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Burners won`t stay lit.........
There are several possible causes for this. Bad flame sensor, bad thermostat switch, blocked air vent, or bad gas coils.
This website
Has very good troubleshooting and repair information for all of the possibilities
Feb 02, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Gas will not stay lit.
sounds like a bad coil
they are on top of the gas valve
Jul 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Igniter works fine but there is no flame so therefore no heat
Replace the coils on this burner assembly. this will fix this issue you are having at this time.
The coils open and close the valves, which are responsible for gas flow. these coils are damaged.
May 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Flame goes out after 5 seconds
the thermocupple is a small tube that when heated shrinks to let gas flow if it is no good gas will not flow change the thermocupple thank you for useing fixya please rate me
Feb 24, 2009 | Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
1,445 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
