Question about Motorola Talkabout T5950 (7 Channels) 2-Way Radio
1 talkabout not working
One talkabout works when i talk into it, but when i talk into the other one, the speaker of the first one does not say anything.
  • May 11, 2010
    Does the first one (the one that you say doesn't talk) receive at all? There is a monitor button on the unit so you can listen on the channel. When you press it, do you hear static?
  • Motorola Master
  • 1,640 Answers
Check the programming of the channel, interference eliminator and the Qt filter. These must match on both radios. Here is a link to the user manual to assist you: http://direct.motorola.com/ENS/T5920_T5950%20User%20Manual.pdf
Posted on Feb 17, 2009
What frequency does my motorola talkabout have
If they're all set to the same "Channel" and "Code" you will be able to talk between them.
Apr 15, 2014 | Motorola Talkabout T5300 (14 Channels)...
TalkAbout MR350 not hear Talk About MD200
Check your CODE settings. From your description you likely have the CODE set to a different number on the MR350 than the MD200. I would guess the MD200 is set to zero since you can hear the MR350 when it transmits. Set your codes to match one another, and turn off any special features such as call alert or Qt filtering.
Ordinarily I would post links to the user guides, but FixYa seems to be having a problem with this feature today. If you need the user guides visit giantintl dot com website.
Best regards.
May 22, 2013 | Motorola MR350 Two Way Radio
I have a pair of motorola t5500 one of them will not talk to the other . one works fine and you can talk into it and hear from the other but the 2nd one when I press the button and talk you hear nothing...
Change your CODE to be zero on the 2nd unit. Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
If this doesn't solve the problem, check the frequency, code and Qt filter to be certain they are all set the same. Lastly, switch the battery packs between the units and see if the problem moves to the other unit. It takes more energy to transmit than to receive.
Best regards.
Jan 16, 2010 | Motorola Talkabout T5500 (7 Channels)...
I have a Motorola Talkabout T5710. I no longer
Perhaps the privacy code has been changed on one of the radios? If you have a manual follow the instructions for setting the codes and make sure they are the same on both radios.
Jan 01, 2010 | Motorola Talkabout T4500 (7 Channels)...
Sends transmission okay but, even with volume set high it receives faintly.
You have one of three problems:
1) You are using the radio with another model of radio which is set to wideband channel spacing. (The TalkAbout is narrowband.)
2) You have a radio with a problem. (bad speaker, or plugged speaker grill possibly, or an internal issue)
3) The transmitting radio has a problem, or has debris or something covering the mic hole.
The only way to narrow down the problem is to have a third known good radio in the mix. This will let you know which radio is problematic. The TalkAbout models are for the most part non-repairable (other than the TalkAbout Distance models and the T7200 and T7400.)
Nov 07, 2009 | Motorola Talkabout T6220 (14 Channels)...
Hi, i bought a Motorola CP200 radio and realised that it didnt work with my Motorola Talk-abouts! now i know that there is a programming that i need to operate with!!! so my question is....how can i know...
Take it too radio-shack and ask the salesman to try out a frequency meter to get the freq. you can get programming help by contacting motorola direct...1-800-638-5119
Aug 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Dec 16, 2008 | Motorola Walkie Talkie 2-Way Radio
I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Jul 26, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
The talkabout t5500 and the t5725
Hello bella-9,
The T5500 is a 2 channel radio and the T5725 is a 14 channel radio. However, the radios should be compatible with each other on FRS channels 1-14 as long as both radios are using the same Quiet Talk code. If the Quiet Talk settings are different the radios will not be able to communicate with one another.
Assuming all settings are the same (as you say) and the units are within range of each other (typically less then a mile over clear, level terrain) they should work just fine.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 16, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5950 (7 Channels) 2-Way Radio Logo
422 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Iron
Iron
OBHighflyer
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
