Question about Mintek DTV-373-D 37 in. LCD HDTV
TV has sound and a black and white picture with satellite input
After a move, I recently hooked up our flat screen Sylvania TV to a Directv satellite receiver, same company but a different receiver than we previously used, and DVD/VCR unit. When playing a DVD the TV displays color, but when using the satellite the picture is in black and white and grainy.
Although the TV has inputs for S-Video, I only have composite cables (yellow, red, and white). There is no input on the TV for a coaxial-type cable.
How can I get a color picture, and improve picture quality with the TV connected to a satellite reciever and DVD/VCR unit?
SOURCE: On-screen Menu
Actually, it is not a Projection TV Problem. The problem is with a Mintek DTV-265 26" flat screen digital TV (not projection). I have not yet resolved the problem by unplugging the set, pressing the eject button and replugging in the set nor have I had any other suggetions. The manual clearly indicates Mintek DTV-265 26" (not Mintek DTV-263) but I feel they are very similar; however, the manual does not mention losing/restoring the on screen menu.
Posted on Feb 29, 2008
ryan7
  • 11 Answers
SOURCE: Mintek Fix
It may be a little different on the 26" model. It's been several months since I did the repair so my memory is a little fuzzy. It sounds like the non flat strands are a common ground and the flat ones are the hot wires. The best thing to do would be to take a multimeter and test for continuity on the center of the RCA jack and the flat strand of metal. If you get a reading, that is where the input wire should be soldered. More than likely you're correct and you should proceed as you found logical.
All you're really doing is making a new connection for the component input on the back of the TV. So just make sure that each hot wire from the DVD player will be on the strand of metal that corresponds with the hot wire from the component RCA jack, which is the center part of the jack, not the outer metal sleeve. In theory you could just attach all of the grounds from the DVD player to any metal part of the TV; I do not know if this will work however because the set might have a failsafe on the motherboard, not allowing video pass through when grounds are not detected.
I hope this helps! And please let me know if you get it working or have any other issues.
Ryan
Posted on Mar 11, 2008
ryan7
  • 11 Answers
SOURCE: Mintek Fix
Mike
The biggest reason is the input on your TV will be stuck in DVD mode. Therefore the set expects any audio to becoming from the DVD player and not inputs on the back of the set. So every input on the back of the TV except for the component input is non functioning. Another reason is that you have no way to control the volume of the TV since there are no functioning buttons save the power button.
If you cut the speaker wire in the TV and solder to the respective RCA connections on the back or side of the TV you can treat the speakers passively, meaning there must be some sort of amplifier to power them. You could also just splice some wire to the cut speaker wire to extend the speaker connection to an amplifier, but I'm not a fan of loose wires coming from the back of my TV.
Therefore, using this set up you would have your cable box attached to your TV and an amplifier of some sort, and the amplifier attached to the RCA connections you soldered for the speakers.
Here's an amplifier that would work for fifty bucks:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-958
To turn the TV on just make sure the power button is pressed (this will put the TV in standby) and then press any other button on the side of the TV: Source, volume, any of them will work.
In order for your cable box's remote to work it will need to be programmed for the TV. I have been unable to find the program codes for the TV, but I do know that Comcast's cable remote will work if you do the code search. You do need to reconnect all the grounds that you disconnected as well.
Let me know if you run into anything else
Ryan
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
  • 10865 Answers
SOURCE: Connecting DVD to Video 2 on TV
on the remote control there is an input button. push input and then select one option at a time until you have the connection.
Posted on Apr 21, 2009
Directv can't connect my tv to he, what can I do, they say I need a green plug in in the back,with the red, yellow, white
What I believe they are trying to tell you is you need to hook up into a component input . It is a video input only and it has three jacks usually coloured red green and blue. Match up the colours with the receiver and you will get an HD picture. They way you currently have it hooked up is a composite connection with only the yellow being for picture. This cannot get you an HD picture. The red and white is for the sound. I don't know what you mean by he though.
Sep 24, 2015 | Emerson 42" Plasma Tv Pl-p42w-10a 720...
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
Hooked up a Directv box to the tv, with rca cables(red white yellow). How do I get the tv to show the right screen for a picture? Model # 6432GG
The Remote for the TV set itself should have either a input or source button on it (some call it tv/video) If you are hooked to a set with more than one set of the jacks they will be labeled video 1 or 2 etc.
simply with the remote for the tv change inputs until you either see the picture or the display matches the location you plugged into.
Dec 05, 2012 | Sylvania 6432GG 32" TV
My polaroid fxm-1911c picture is distorted, sound distorted with loud buzzing when I try to utilize the tv signal input jack, also the dvd player doesn't work
Looks like there are some partial defects in the TV and might need attention of a qualified service technician. Anyhow, make sure that the input cable, RC jacks and sockets all do not have any loose contacts. Go through settings and ensure that every set up is as it should be.
Aug 02, 2012 | Polaroid FXM-1911C 19 in. LCD Television
Hooked tv up t DirecTV and I have sound and a picture, but my picture is black and white.
first check connection cables and make sure they are in the right place, if you are using component inputs then if you change them around the wrong way it will cause this or is one cable is bad, I would try RF and see if it's black and white also, or use HDMI like dvd and see if it's also B/W if not then it's in that input the problem.
Jan 11, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Mar 09, 2009 | Televison & Video
13" Orion TV having display issues...
There may be a short in the video game system, which could have fried something in the input circuits. And of course, make sure you have your TV cable plugged in, and the TV set to cable position before determining that the TV has an actual problem. Unfortunately, some functions may only be on the remote of course.
Jan 02, 2009 | Sylvania 6427TE 27" TV
HS500, white/light at top of screen
I believe input 5 is hd input wich is different from the others
you may want to try hooking the sat to any component input to find out if there is any difference
Jul 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Audio
1. Make sure you have connected the cables from audio OUT on the Directv box to the audio IN on TV input 3 and have selected the correct source on the TV.
2. Many sat boxes have an audio volume control. Select the satellite box on the Directv remote and turn up the box's volume.
Hope this helps.:)
Apr 01, 2008 | JVC AV-56WP30 56" Rear Projection...
Mintek DTV-373-D 37 in. LCD HDTV Logo
249 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
