Question about Kodak EasyShare C330 Digital Camera
Camera no longer working
Each time the camera is switched on an image of a memory card appears and a message saying the memory card is protected and advises that I need to reset the switch on the card. I can only review photos I have already taken. The camera is about 3 years old.
  • Bez Feb 18, 2009
    Fantastic! Thank you, you were spot on with your solution
  • 423 Answers
Your memory card must have had the switch moved from locked to unlocked. To fix this, removed the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says locked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on. Try it and let me know if I can help more.
Posted on Feb 17, 2009
Memory card is protected {reset switch on memory Card} ? Go To review
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 26, 2014 | Kodak EasyShare M530 Digital Camera
My camera says my memory card is locked but the button on the side is not locked how do i retrieve my pictures i have a canon powershot a480
Issue: [Memory card locked] message appears on the screen.
Solution: Change the memory card lock switch to the normal setting
The SD card has a lock switch to prevent existing data from being erased. To record images or movies this switch must be in the normal (non lock) position. Different brands of SD memory cards may identify this switch differently. Regardless the procedure should be the same. Please remove the card from the camera and ensure that the switch is not in the locked position. sdcardlocked.jpg
sdcardunlocked.jpg ---
You should be able to retrieve photos, but not writing or erasing if the switch is switched to write protect.
If it's not functioning correctly, the camera may need service at Canonusa.com.
Jun 19, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
I downloaded some pictures to my school computer and now my camera won't take any pictures. Message is Memory card write protected.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 26, 2010 | Nikon Coolpix 4500 Digital Camera
Cannot delete photos" Card Protected" appears on screen
There should be a small switch on the memory card that allows users to lock it so no one can delete pictures on it. Take the memory card out of the camera and look for this switch on the card and make sure it is not in the locked position.
May 19, 2009 | Sakar 87492 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Locked Card
Change the memory card lock switch to the normal setting84b4934.jpg3c6d94b.jpg
Good luck....
Nov 18, 2008 | Canon PowerShot S51S Digital Camera
How to unlock the memory card of my digimax S500/S600
Your card is protected.
Jun 24, 2008 | Samsung Digimax S500 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Kodak EasyShare C330 Digital Camera Logo
77 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
