Question about Samsung Q1 Ultra Tablet PC
Q1 ultra not booting
My samsung q1 ultra all of a sudden stopped. It was working fine but now it is not turning on at all with battery or power supply. Tried different battery too fully charged but no luck. Help will be appriciated.
Thanks
  • colonel1 Mar 29, 2009
    My new Q1 will not boot up. It booted once with the the mesage that "Windows has just resolved a serious error" and then went down again.
    My company did not give me the manual with it. Where is the memory card?
  • rfguha Apr 28, 2009
    My Q1Ultra will not boot up. It doesnt even get to the SAMSUNG screen. Just the power and mouse buttons light up and then its stuck.
    I tried replacing the RAM but that didnt help. Not sure what to try next. I bought it in the US and not sure if the Samsung Service center in my country (India) can fix it so would appreciate any thoughts.
Fixed it. Opened the back cover and reinserted the memory.and it bootedup. So I guess memory got loose.
Posted on Feb 18, 2009
How to fix not working touchscreen? Do i have to replace it?
The Samsung Q1 is a hybrid, ultra-mobile, touch-screen device that is basically a very small tablet PC. It features a 7-inch screen, weighs a mere 1.7 lbs., features a Windows operating system, doesn't have a built-in keyboard, and comes in a variety of configurations. The Samsung Q1 doesn't offer outstanding battery life, but you can make some moves to boost your computing time.
Dim the Screen
Dim the screen brightness. Four programmable application-launch buttons occupy the right edge of the Q1. One of these, the menu button, calls up frequently-used controls, including screen brightness. Reduce the screen brightness as much as you can, as it's one of the best ways to extend battery life.
Close Power-hogging Apps
Close applications and browser windows when you're done with them. Too many open programs drain the battery. Beware power-hogging apps. Watching a video or listening to music on your Q1 drains your battery life much faster than just using Microsoft Word or checking email. Turn off the Wi-fi networking when not in use. The built-in Wi-fi searches for a network when you're not connected, which drains battery life.
Properly Caring for and Feeding a Battery
Unplug the Samsung Q1 after the battery is fully charged. Leaving your Q1 plugged in 24/7 leads to some discharge from the battery. Consider buying a bigger battery. A 3-cell battery comes with most configurations of the Q1, but you can also buy a 6-cell battery to double the battery life.
Room Temperature is Best
Don't expose the Q1 to harsh conditions. Keeping the device in a blazing hot car in direct sunlight harms your battery life. If you use your Q1 in conditions above 95 degrees Fahrenheit, you can permanently damage the battery. Cold conditions don't harm the battery in the same way, but if you leave the Q1 in the cold, let it warm to room temperature before you use it.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Samsung Q1 Tablet PC
I have a Samsung Q1 Ultra After my Last Travel , It is NOT Powering up and It is not even getting " charged" when connected to Power adapter. can you help solve this...
This is most likely going to be one of two things.
-The DC jack is damaged. Caused by having the adapter plugged in and someone or something jarring it to the point that the solder joints break. -OR- -The motherboard is damaged.
You can test, sort of, for the first. Plug in the adapter and gently wiggle it around, while at the same time pressing the power button to attempt to turn it on. If it powers on briefly then you will the DC has broken solder joints. If it doesn't then it's probably the latter.
The motherboards are made in korea so this maybe the only place to get one http://www.asianproducts.com/product/A12388339962328843_P12394341336085231/samsung-q1-notebook-mainboard.html
Jul 10, 2011 | Samsung Q1 Tablet PC
I cannot adjust the brightness of my samsung N150 plus mini laptop
me too, same problem...going into the bios and changing to user controlled makes no difference, also changing the power settings makes no difference - even if unplugged.
anyone know?? much appreciated
Dec 20, 2010 | Samsung Q1 Ultra Tablet PC
Where can I find parts for my NP-Q1U Q1 Ultra Tablet PC (Samsung)
wht kinda parts you looking for? I have one I just broke. I'll sell ya parts. photrum@hotmail.com
Sep 24, 2010 | Samsung Q1 Ultra Tablet PC
Samsung q1 bios password reset - how?
why cant i change my bios password for my samsung np-q1
Feb 01, 2010 | Samsung Q1 Ultra Tablet PC
I need to install an operating system on a Samsung q1 ultra
Suggest you use an external DVD drive, and put your installation disk in it. Then access the BIOS Setup utility.
In BIOS Setup, find the Boot Order menu. (Generally, along the top headings of the main menu, in BIOS Setup, or located in Advanced BIOS Settings) Set the first boot device to be CDROM. Be sure to Save your change.
This way the handheld, will boot from the installation disk, in your external DVD drive.
Should you be trying to downgrade from Vista to XP, you have to change the first boot device, in Boot Order to CDROM. If not, Vista won't let you overwrite it.
Vista is an upgrade over XP.
Apr 21, 2009 | Samsung Q1 Ultra Tablet PC
Black screen at power on
I had the same problem. I pull of battery and then immediately reattached and ta-daaaa! Windows came right up!
Hope this helps!
gg
Jun 23, 2008 | Samsung Q1 Tablet PC
Samsung Ulta Q1
stylus is controlled by the softwares , sensors are working fine in the pc . software problem is mpre likely then a hardware , try re-installing the OS , if it doesnt work the only you refer the company people (the manufacturers)
Nov 06, 2007 | Samsung Q1 Tablet PC
Samsung Q1 Ultra Tablet PC Logo
863 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
