Question about Epson LQ-2180 Dot Matrix Printer
COMMON TROUBLES OF PRINTERS,TROUBLES OF DISPLAY MONITOR?10 BRAND
1.what are the causes of troubles?
2.what will be the eremedy?
    Sergeant:
  • 366 Answers
If you list the trouble we'll be able to help..
Posted on Feb 17, 2009
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Tip
Trouble with heart rate monitor reading heart rate.
Can't get a heart rate to show on your heart rate monitor? If there are no other issues with the watch, then most likely what you are experiencing is an issue with the Heart Rate Strap.
It is very common for all brands of heart rate monitors to have issues with measurement.
The #1 reason is poor contact with the strap and your skin. - Make sure the contacts are wet and touching the skin with good contact.
#2 reason - Weak battery, may need to replace.
#3 reason - Sensors on strap have salt build up from sweat - Clean the strap and contacts with soap and water, if deep cleaning is neccessary use a q-tip and some rubbing alcohol.
#4 reason - Strap is too low on the body, raise as high on the chest as possible to just under the breasts. Strap too low will cause a weak signal.
If none of these seem to help, then you should contact an authorized repair center or the customer service for your brand, and see about possible repair or exchange/ return.
on Dec 06, 2010 | Watches
Tip
How to change your Windows 7 display settings In Windows 7 there are serveral...
In Windows 7 there are serveral ways to get to your display settings. I have detailed them below in options so that you can access them as needed.
Option 1
Right click on your desktop and select "Screen Resolution"
Option 2
1. Right click on your desktop and select "Personalize"
2. Next click on "Display"
3. Click on "Adjust resolution"
Option 3
1. Click the Start button and click Control Panel
Once you are in the Screen Resolution you can set the resolution you want.
Note the resolution that is set now is a wide screen resolution. If you have a standard monitor the equivalent resolution would be 1280 x 1024.
After you have made the needed changes click on Apply then OK to save your changes.
Note if you are still have trouble with your monitor displaying right you may need to install the monitor drives. Windows is not going to have the actual drivers for all monitors. So in picture below you will see where is shows "Generic PnP Monitor" this means that the computer is using a generic driver. You can access this screen by clicking on "Advance Setting".
If you need to install the monitor drivers the link below will take you through the steps of installing the monitor drivers.
http://www.fixya.com/support/r4290666-install_monitor_drivers_in_windows_7
Other Helpful Links
How to change your Windows XP display settings
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Mar 08, 2010 | Computers & Internet
Code 3452 and my touch screen is not working
These could be related problems, however I doubt that they are. The error code 3452 refers to thermistor not reaching temp within specified 30 second time frame. There is a sensor there that monitors this. Touch screen may not work due to error code. However, I'm a little suspect that it may be a different problem. But first, let's solve the initial issue and then move onto the screen.
Try clearing the error code first, and then if it appears again, you'll need to look at replacing either the sensor or thermistor. If you are not a certified technician, but attempting to resolve yourself, I would suggest sending the fuser back to whomever you purchased it from and telling them to supply you with another one. During rebuild they probably did not properly gauge the sensor from the fusing roller. therefore it is not able to properly monitor temperature. (very common problem)....
Here is the instructions for clearing the error code:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while holding down the Utility/Counter key more than 10 seconds after. A screen will appear saying "TROUBLE RESET"
3. Touch "TROUBLE RESET".
4. Check to make sure that "OK" is displayed below which confirms it has been reset.
If "OK" is not there , it will show a different code....
IF it says "OK", you should be good to go. Error code should now be cleared.
5. Just Turn off the Main Power Switch wait at least 10 seconds....and turn it on. Make sure that the machine properly starts.
** If it re-displays the code again within a short period of time, replace the fuser unit. Or get a certified technician to replace the or adjust the sensor or Thermistor unit. However, since you just purchased this I will assume that it is either a defective unit from manufacturer, or the company who rebuilt it did not properly ensure it was working. Return it and demand a replacement in EITHER case!! J
Hope this helps
Sep 02, 2011 | Konica Minolta bizhub C450P Laser Printer
Screen display is sideways
Hi all5r_mine,
Based on your situation. I suggest trying the following options:
Upside Down or Sideways Monitor Display
Problem Description:
The user accidentally pressed a keyboard combination that turned the entire monitor display upside down or sideways. The user cannot recall the keyboard combination that caused the problem and has no idea how to rectify the display.
Possible Solutions:
Some graphics cards have rotation "hot keys" enabled by default and this is probably the most common cause of this problem. The exact procedure for rectifying the display may depend on the particular brand and configuration of the graphics card in the problem computer. One of the following options may help resolve the issue.
Option One:
Try using the keyboard combination, "Control + Alt + Up Arrow Key". Control + Alt along with one of the arrow keys is a fairly common rotation hot-key configuration and may just do the trick.
Option Two:
If Option One doesn't work, see if there is a graphics card icon displayed in the Notification Area (near the Windows Clock). Clicking (or right-clicking) the icon may reveal a "Rotation Settings" option that will allow you to revert to "normal" display.
Option Three:
If neither of the previous options help, try the following procedure.
1. Right-click an open area of the desktop and click "Properties" to open the "Display Properties" window.
2. Click the "Settings" tab and then click the "Advanced" button to open the monitor settings window.
3. Click the tab corresponding to your graphics card. You may need to click one or more buttons within the tab to reveal a rotation settings option. Exactly where rotation settings are located will depend on the brand of graphics card installed.
4. Once you locate the rotation settings, choose the "0 degrees" or "normal" option to change the display to upright. The rotations settings may also give you the option of disabling rotation hot keys so that the problem does not happen again.
5. Click "OK" to save changes and exit out of any open properties windows.
Navigating through menus and choosing options when the display is abnormal is difficult but certainly not impossible.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Acer Computers>Laptops Aspire 5610-2013 PC...
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
I turn the computer on and the monitor will stay dark even though it is turned on. Then I turn the monitor on and off a few (10) times and eventualy the poicture comes through. I have the monitor hooked to...
It may be caused by 2 reasons:
1. The notebook is not correctly configured for an external display - you may need to install the display drivers or update it.
2. The backlight inverter on the display may have problems and need repairs. Check if you can see a faint image in the screen.
Oct 10, 2009 | Samsung SyncMaster 203B LCD Monitor
The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Mar 31, 2009 | Konica Minolta bizhub C250 All-In-One...
Epson LQ-2180 Dot Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
