Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Hdmi wont work and it used to how do i reset the plasma
I had bought a( h.d.m.i )wire to go to my ps3 and my computer and it worked 4 the computer but diddent work for the ps3 and i went to use the (h.d.m.i) wire for my computer like i normally do but this time its not working.i tried to reset the plasma but dont know how i tried unplugging it but still no results
  • 4 Answers
You have to set up your PS3 to use the HDMI connection. what you need to do is hook up both the component and HDMI to your tv and turn your PS3 on, the you have to go to "Settings" and find the video output settings (Sorry, i don't have the PS3 on so I can't check out exactly where to go) and select HDMI.
Your screen will go black and you have to switch over to the HDMI on your tv and select ok on your PS3
Posted on Feb 20, 2009
Ressetig the ps3 on a new tv
Sounds like the Tv your using is faulty. Its could have hardware failure. You did say it PS3 was working on hdmi on a plasma. If your using the default hdmi cable that came with ps3 that also can be faulty. I have always had problems with the default hdmi so i bought a new one that was not SONY and it works beautifully. Another thing the black screen with green is a video cable or graphics issue.
Does this tv work if there is no ps3 connected? if so i recommend using the standard PS3 Component AV Cable. see if that will let you reset your ps3.
Jun 24, 2014 | Sony Playstation 3 (PS3) Console
When I hook up my LG plasma to PS3 and Cable box, I don't get any sound or colour on the PS3. The TV /cable box works fine. Any ideas on the wiring?
What type of connections are you using? HDMI? Component? Composite? What audio? HDMI? Optical Digital? Analog audio?
Are you saying you get video from the PS3, but it is in Black&White only? Is there an NTSC/PAL selector on the PS3? If so, it may be set wrong. Set to NTSC if you're in the United States.
Feb 01, 2013 | LG 50PC3D 50 in. Plasma Television
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
My ps3 wont show on my tv anymore. what do i do?
not to worry it is very simple
1. if u are using hdmi port and it is connected to hdmi in your tv
setting might have been changed
1. take out ur nomal av output wire which is given by sony , plug it on to a normal tv (rgb) now u can see the display (if not try mannual swithch off the ps3 and on for 3 to 4 times) u will get the display
2. now go to settings (video settings) there is a option called video output u can change it to AUTOMATIC
3.NOW COME OUT of it and switch off
4. now pug into ur hdmi port it will work
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont work with AJAX after using HDMI cable
ps3 does not reset the video automaticly you have to reset it yourself any time you go from one mode to the other
to do the vid reset just hold the power button when in standby(red light) untill you hear second beep then release
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
My PS3 wont display.
you could use the hdmi cable or the composite cable(like the old playstation one with the 3 leads but different colours,not red,white,yellow.)
both would be better for a plasma.
make sure your screen can utilise 1080 for hdmi.
if 720 or 480 use the composite cable.
Feb 27, 2009 | Sony Playstation 3 (PS3) Console
My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
welcome to fixya
you have to set it up on the ps3 for the cable
i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
Aug 01, 2008 | Sony Playstation 3 (PS3) Console
My PS3 only works on my Plasma tv's HDMI channel. None of my other tv's have this HDMI channel. Why doesnt my PS3 work on any other channels or my other tv's? Could anyone help out with that?
When you have the ps3 hooked up through av cables on crt tv not hdmi. Continue to hold power until the console beeps again and this will reset which audio video output resolution back down so it can be seen and heard. Hope this helpes.
Jul 13, 2008 | Sony Playstation 3 (PS3) Console
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
426 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
