Question about HP Compaq Presario SR1575CL (PX808AA) PC Desktop
Trying to restore to factory default using f10
Wont respond when f10 is pressed nothing hppens
  • Anonymous Feb 17, 2009
    I dont have cd but I guess I can get fron hp
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    If F10 isn't bringing you into the system recovery for your compaq then your recovery partition is corrupt and you'll need to use the discs to restore your system back to factory defaults. Do you have the discs?
  • HP Master
  • 3,051 Answers
Hi there
if you have your restore cd that came with the computer install it and turn off the computer than restart the computer and the cd will come upo saying welcome to windows restore than it will ask you if you want to restore and say yes and let it do that than when it is done it will reboot the computer
Posted on Feb 17, 2009
Aspire one d257-13473 wont factory reset
Windows key > All programs >Acer Empowering Technology>eRecovery management>Restore>Factory(Top of list)..
Or
If computer will not boot.
Tune computer ON
When Acer splash is on screen hold Alt and keep pressing F10...
Select factory from top of list.
You will need a password , the default is "000000" (Six zeros).
Recommend you use the first option if you can...
1. Power on the machine.
2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts.
3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.).
4. Click "OK" to continue.
5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit.
***This will erase all your unsaved data!***
Or
Running System Recovery from Windows
1. Click Start>All Programs>Acer Empowering Technology.
2. Select Acer eRecovery Management.
3. Select Restore (bottom of eRecovery screen).
4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.).
5. Select Yes then Next, the system will reboot and start the recovery.
Or
1. Reboot, and press F8.
2. Select Repair.
3. Select Reinstall Windows and follow prompts.
Dec 06, 2013 | Acer Aspire One D257-13473 Netbook
Hp compaq laptop how to restore to factory default?
Go to Start/All Programs/HP Tools/HP PC System Recovery
If this doesn't work then try pressing the F10 key multiple times during the bootup to access the recovery console.
If this still doesn't get things fixed then you need to re-install XP
If this answer helped you then do visit my blog TECHAMY
Jul 09, 2012 | HP Computers & Internet
Black screen flashing dash top left corner. ....wont reboot after system restore
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Apr 03, 2012 | Computers & Internet
Acer Aspire One D250-08K Need to restore to factory settings and i have no disc. Screen is black. On start up pressed ALT F10 then nothing happens
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Aug 29, 2011 | Acer Aspire One PC Notebook
I dont have the instillation cd
well without an installation cd you wont be able to install whatever it is??? unless you download it from the internet but if its an operating system and you dont have one to connect to the net you are in trouble or might try factory defaults if your operating system is giving problems
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos restart
hope this helps
Jul 16, 2011 | Computers & Internet
I need help on restoring my compaq armada e500
Hi Welcome to FixYa!
You could try these steps on restoring your laptop into its factory defaults.
1)Turn off your computer if it is on. Wait for the system to shut down completely. Once it is off, press the "Power" button to turn it back on. Press the "F10" button at the top of the keyboard repeatedly as soon as you see the screen turn on. This will let you enter the setup menu.
2)Use the arrow keys to move between the various menu tabs at the top of the screen. Press the "Right" button until the "File" tab is highlighted, then press the "Enter" button to enter this menu. Here you can make changes to the settings of your computer, or in this instance, restore factory default settings.
3)Use the "Up" and "Down" arrow buttons to move to the "Restore Defaults" option, then press enter. You will see a screen asking "Are You Sure You Wish to Restore System Defaults?" Press the "Y" button to continue. The system will begin restoring your default settings. Do not press a button until a screen says "System Defaults Restored."
4)Use the arrow keys to move down to the "Save Changes and Exit" option and press "Enter." The system will save your changes and automatically reboot your computer. You do not need to press "F10" this time as the computer will start Windows normally. You will see the factory settings have been restored once the system loads.
Hope this could help!
  • Jul 07, 2011 | Compaq Armada E500 Notebook
    My friend Sony Vaio Laptop is formatted by a person and also installed windows xp . Now the Laptop has'nt original recovery tool to restore the system to its Factory default... I need the DVDs to for...
    Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
    Hope this helps
    May 20, 2011 | Computers & Internet
    I did an update for my sylvania smartbook and now it wont do anything. i want to restore it back to its original settings.
    During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer
    hope this helps
    Mar 22, 2011 | Computers & Internet
    My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
    http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
    Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
    This could be your HDD, failed. Work through, the troubleshooting procedures.
    Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
    May 14, 2010 | Acer Aspire 4315 Notebook
    try to remove the bios battery for a second..it will reset the bios to the factory settings ...it might just work ...
    I believe that the problem its one that developed after you changes some settings or after you installed some device that use that key for a different action ...
    May 27, 2009 | HP Compaq Presario SR1575CL (PX808AA) PC...
    HP Compaq Presario SR1575CL (PX808AA) PC Desktop Logo
    339 people viewed this question
    Top HP Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
