Question about HP Color LaserJet 2600n Printer
I have black streaks on my copy
I replaced my black toner cartridge and I now receive a black streak on
the right side of my copy paper.
  • Anonymous Mar 20, 2014
    copier has large black streaks on them
    Problem Solver:
  • 11 Answers
Before you installed the cartridge was it in the box standing on end, If so remove the cartridge from the printer and gently shake the cartrige from side to side then reinstall, the toner may be packed mostly on the one side.
Posted on Feb 17, 2009
I have an hp LaserJet 3015 PCL-6 all in one printer, copier & fax. When I use the copy function, there is a black streak running down the length of the copied paper. I tried replacing the toner...
Clean the thin glass strip that sits to the left of the flat bed glass.
That is the glass used when the ADF is being utilized.
There is dirt on it causing the black streak.
Oct 11, 2011 | HP LaserJet 3015 All-In-One Printer
Tip
Why i get black streaks on paper in laser printer prints?
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks .
on Mar 18, 2010 | Office Equipment & Supplies
Every copy has large black streaks across the page
Are the streaks horisontal or vertical on the page?
What printer? Laser or InkJet?
If laser, and streaks are vertical, you might have some dirt stuck in teh tomer cartradge or somewhere along the paper path
If laser, and streraks are horisontal, your toner cartridge might be dirty or leaking toner
Aug 23, 2011 | Office Equipment & Supplies
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
Printing a large black streak of toner on rt side of page
Hello! Malik Muhammad Mehran Here... your problem solution is that you must replace the cleaning plates in the cartridge...
Mar 28, 2010 | HP LaserJet 6L Printer
I'm getting black streaks down the left side of the paper. There is plenty of toner left in the cartridge. We've vacuumed out the printer, cleaned the drum - nothing helps.
black streaks the toner cartridge is leaking from the left side which is easy to check pull the tone and look at the gears on the left side to see if toner is present. if these gears have toner on them the cartridge is leaking replace it. check the fuser for wear marks on the hot roller which is the top roller when these get worn through the outer coating they will create black streaks
Dec 05, 2009 | Lexmark E238 Laser Printer
Canon pc920 black and white copier white streak on copy
PULL OUT THE TONER CARTRIDGE AND SHAKE IT, IF THAT WORKED A BIT BETTER THE CARTRIDGE NEEDS REPLACED.
Apr 07, 2009 | Canon PC-920 Black and White Copier
Black Streaks
pull drum unit out and clean corona wire by sliding blue plastic tab from side to side, making sure you put the tab back on the side that it was. if that doesn't take care of problem, then i would say you need a new drum unit.
razors
Jan 27, 2009 | Brother MFC-8440 All-In-One Laser Printer
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
HP Color LaserJet 2600n Printer Logo
444 people viewed this question
Seeker5211
Seeker5211
