Question about GE Refrigerators
Water dispenser does not work
I've had the refrigerator now for 7 years and has worked fine. Now, the water dispenser does not work. After about 6 weeks, it miraculously fixed itself only to let us down after about 2 weeks. I'm stumped...I've tried all the troubleshooting suggestions in my owners manual and even some that I've seen posted online (such as hair dryer, etc.).
  • 172 Answers
One of the following items is most likely the problem.
The inlet valve. The dispencer switch. the water filter, or the water storage tank.
If the ice will dispence then you can eliminat the dispencer switch. If you have heated the tank in the freshfood section then you can eliminat the tank. You may also have a frozen water line. The most common would be the inlet valve. it is located on the back of the refrigerator. It is the item the water line connects to from the wall. You can feel free to give us a call and we can help trouble shoot.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Feb 17, 2009
Samsung refrigirator water dispenser works without filter but does not work with filter
Not enough water pressure in supply line to get past filter?
Open valve feeding supply line more and see what happens.
Sep 06, 2017 | Samsung Refrigerators
Hello, I've been using the "Whirlpool 25.1 cu.
Maybe trash has made its way to valve and it is partially stuck open. Or maybe all air is not out of line. Run water through dispenser until it stops splurting air and there is a steady stream of water.
Sep 23, 2017 | Whirlpool Refrigerators
Our fridge is a little over 6 years old and everything has worked fine until now. Earlier in the day I was able to fill up a glass of water no problem but now no water is coming out of the dispenser. The...
Usually that is from the water line freezing up. Behind your refrigerator drawers there is either a plastic tank or a coil of plastic tube........That is where the water runs so your dispenser puts out chilled water. If your fridge gets too cold that will form ice inside and stop the water from flowing. You can defrost it with a hair dryer or just let the fridge sit open for a few hours. Another thing could be the water valve. When you press the water lever on the dispenser do you hear a noise? Kind of a humming noise. Well, that is your water valve, so if you hear it then it is probably working.
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser not working
See my earlier post of 6-4-09 for the solution to this problem. There is a GE part you can buy the solves the problem. It is part #WR49X10173 -- it's called a "Dispenser Water Tube Heater Kit". The part costs $32-35. GOOD LUCK!!
Apr 12, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Water Dispenser not working
If the ice maker is working, and no water is coming out, the water line may be frozen.  This happened to me yesterday, and I followed the advice on ehow.com.  It worked like a charm! Take a hair dryer, and blow hot air up into the dispenser tube, holding the hair dryer about 8-10 inches away.  After about 5 minutes or so, a tiny chip of ice and a couple of drops may pop out.  Fill up a couple of glasses of water to flush it out, and you should be good!
Mar 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
