Question about IBM ThinkPad R50e Notebook
Power button does nothing!!!
I was runing a chkdsk /r on the c drive half way through one of the last checks ... the computer turned off... now the power button does nothing.... could this be my power supply... desktop computer... on the mobo there is a green light that still shows on when plugged into ac power.... any suggestions would be appreciated
  • spud69_7 Feb 17, 2009
    this is not a thinkpad... it is a cutom box desktop computer with asus a7a266 mobo
    Thanks alot for your reply so quickly....I never thought reseting the cmos would help but a great idea none the less.... turns out my uncle has a power supply tester.... power supply is a brick.... which gives me insite to the real problem that I was trouble shooting... explorer problems... and constant chkdsk.... power supply has been on the blink for a while I suppose.... hooked the computer up to a power supply from a second computer all is well....
  • IBM Master
  • 3,051 Answers
Hi there:
hey if you power down the computer and open the case and remove the powercord that goes from the powersupply to the motherboard and than remove the silver battery and let it set for 2 min and than put everything back together you will be able to power up the pc you will get a error saying cmos error you need to update the time and date just select setup and update the right time and date than save and exit the computer will reboot and you shoukld be good to go
Posted on Feb 17, 2009
My whirlpool washer wont start? Hit the power button and the ligths go on and hit the start button and it sounds like it runing but nothing happens takes a will and still noting....
Please have a technician check either the drive belt or the rubber-drive-coupling.
Sounds like whichever one is on your machine may have broken.
God bless your efforts.
Dec 03, 2015 | Whirlpool Washing Machines
Hard drive turns off
Open the power settings , adjust advanced power settings, Change to High Performance. Change Sleep and Hibernate to Never. Shut down your laptop when not in use. It will last longer and a reboot everyday resets the computer.
Dec 14, 2012 | Sony VGN-FW351J/H PC Notebook
Upon connecting the samsung G2 to my laptop, it says "needs formatting" but when click the format disk option it says "disk can not be formatted'
Many errors in Windows are caused by corrupt files. Those files could have become corrupt because of errors on your hard drive. The Check Disk tool checks for errors and attempts to fix any it finds.
Warning: Use Check Disk at your own risk. On rare occasions I've experienced problems when using check disk in Windows Vista. Here are a few things to watch out for:
If you run check disk and your computer has to be restarted to scan your computer and your computer hangs at a black screen when it boots up, do the following: Turn the computer off and back on and immediately start pressing F8 on your keyboard repeatedly. A black screen with different boot options will appear. Select to use the Last known good configuration (advanced) boot option.
Never stop check disk once it has started. It could take hours to days to scan your hard drive depending on its size. How-to Use Check Disk Using the Graphical User Interface (GUI)
Open the Start Menu and click Computer. Right-click the drive you want to perform a check disk on and select Properties. Click the Tools tab in the drive Properties window.
Click Check Now under error checking. To perform a complete check of your hard drive for errors check off both options in the check disk window that pops up.
Click the Start button to start the process. If you are trying to check a hard drive that has open files you'll get a message similar to the one shown below.
Click Schedule disk check. Disk check can't check a hard drive that has open files. Your computer will reboot and check the disk before Windows Vista boots up. If you want to cancel the scheduled disk check for any reason, check out this guide.
Using the Command Line Interface
Check Disk can also be run using the command line (DOS) prompt.
Open the command prompt with administrative privileges by typing cmd in the search box in the Start Menu and right-click cmd.exe in the search results and then select Run as Administrator. Type chkdsk followed by one or a combination of switches listed below in the command prompt. If you run the check disk (chkdsk) command from the command prompt by typing just chkdsk check disk will run in read only mode. All it does is check for errors. It will not fix any errors it finds unless told to do so. This is done by adding switches when typing chkdsk in the command prompt.
A switch looks something like chkdsk /F. Notice the switch /F after the chkdsk command.
Below is a list of most of the switches used with the check disk command. You can use one or a combination of switches with the check disk command.
D: If you want check disk to scan a drive other than the C: drive, add the drive letter after chkdsk to tell it to scan that drive. If the drive is called X: on your computer it would look like chkdsk X:.
/F: The /F switch is the most common of the chkdsk switches. It tells chkdsk to fix any errors it finds. Chkdsk can't fix errors on a disk that has open files. If chkdsk asks you if you want to check the drive next time Windows Vista boots or dismount the drive choose to check the drive next time Windows Vista boots. Never choose to dismount the drive. That option should only be used by a professional.
/R: The /R switch tells chkdsk to attempt to recover any bad sectors of the hard drive if any are found. A bad sector is a spot on the hard drive that can't hold saved data anymore.
/I: The /I switch tells chkdsk to perform a less detailed but faster disk check.
/C: The /C switch tells chkdsk to skip the checking of cycles within a folder structure which reduces the scan time. Don't ask me what this means.
An example of an exhaustive disk check using the command line interface is:
chkdsk D: /F /R
The check disk command shown above will fix any errors it finds and also attempt to recover bad sectors of the D: drive if any are found.
If all else fails, try 3rd party tool SpinRite.
Apr 18, 2011 | Samsung G2 Portable External HX-MU064DC/...
Sony rolly will not play, the unit was dripped, it switches on , it lights up but nothing more , I,ve tried the reset button , a new battery , but still nothing. Any ideas. If not d.o you know the address...
I had same issue on my Rolly. The problem was in the damaged folder on Rolly file system. Fixed this by running error check in windows. Connect your device to computer, open "My Computer", right-click on Rolly drive, Properties -> Tools, click "Check now" in Error-checking area. I used Windows 7I think chkdsk command will do the job as well. Just run "chkdsk H: /F", just change H to your rolly drive letter
Jan 07, 2011 | Sony Rolly SEP-30BTWHI MP3 Player
I have done a monthly backup on my laptop for more than a year, but this time I'm getting an error message "corrupted file system 0x81000008
Run a check disk on the Drive and select Fix bad sectors.
    Running CHKDSK through the Windows Command Prompt:
  1. Go to the Windows Command Prompt. You can do this by clicking first the Start button and then clicking the Run button. After this, type "cmd" in the Open text box and press Enter.
  2. View the displayed Command Prompt screen.
    If you want CHKDSK to run in read-only mode, type:
    CHKDSK c:
    If you want CHKDSK to fix errors and not to check bad sectors, type:
    CHKDSK c:/f
    and press Enter in the Command Prompt.
    If you want CHKDSK to run thoroughly; that is, fix errors, find bad sectors in your hard drive and recuperate still readable data, type:
    CHKDSK c:/r or
    CHKDSK c:/p and press Enter in the Command Prompt.
  3. Running CHKDSK through My Computer (Windows XP)
  4. 1
    Initialize the properties of the hard drive you want CHKDSK to run. Open My Computer. Right click your mouse on the drive in which you want CHKDSK to run. Click the Properties button and click the Tools tab. In the Error-checking box, click the Check Now button.
  5. 2
    Set up the Check Disk options by checking one or both check boxes displayed. These are labeled "automatically fix file system errors" and "scan for and attempt recovery of bad sectors". If you want CHKDSK to run in read-only mode, do not check either box. After this, click the Start button.
Jan 01, 2011 | Western Digital My Book Essential Edition...
Computer comes on half the time, it powers up but no monitor, mouse, and keyboard function. the other half of the time it comes on and then freezes up about a minute or so on boot up, and half the time...
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
then test your power supply unit PSU or replace it
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
then uninstall some unnecessary programs
then click start?run type?cmd then type?chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
you have to keep?a computer very clean & free of dust ?and? give it regular?maintanance
hope this helps
sounds like your computer needs a major overhaul
Sep 21, 2010 | MSI RC410M-L Motherboard
Toshiba Satellite P25-S5093 screen/boot problem
the memory cards are loose or are dirty and need the contacts cleaned with pencil eraser.
when the memory cards lose connection you lose video on screen.
Jun 18, 2010 | Toshiba Satellite P25-S5093 Notebook
I have a HP Pavilion a1140n. The computer froze and was turned off by holding down the power button, but it would not boot up. No light appears on the power button, and when it is pushed, the DVD drive...
hmmm strange first thing id try is resetting the bios it seems it has been effected . remove case remove battery leave off for 3 minutes and replace try then again, while u have the battery out hold the power button on , oh and make sure the power is plugged out, and yeap hold power button for 3 secounds just to drain last of power from power supply. hope this helps
Nov 29, 2009 | HP Pavilion a1140n (PX774AA) PC Desktop
IBM ThinkPad R50e Notebook Logo
73 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
