Question about Whirlpool Duet GHW9150P Front Load Washer
Light says control lock how do I unlock?? my washer control light is on and washer will not operate... any idea how to unlock??
  • mddnl Feb 17, 2009
    I do not understand what removing the front panel means?? And what a strang is... Can you please give some more details on how to remove the front panel and how to get control light off?
  • 360 Answers
Hi, thanks for using Fix Ya,
Here is all you have to do,
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
If you have any questions, let me know.
please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 17, 2009
    Top Expert:
  • Whirlpool Master
  • 77,499 Answers
THE CONTROL LOCK MEANS THAT A FAULT HAS OCCURED IN THE WASHER CONTROLS AND U CAN'T USE THE MACHINE UNTIL THE PROBLEM THAT CAUSED IT I CORRECTED, THIS COULD BE ANY OF A DOZEN FAULTS.
  • 265 Answers
Round the front panel you should proberly see about 4 screws, just remove them and it should just slide of with a bit of force.
once opened you will see a catch, or like a bit of rope with a dongle on it, just pull it hard and your door should open :)
the doors on these sometimes do get stuck but its nothin to worry about :)
  • Whirlpool Master
  • 8,220 Answers
Remove the lower panel and there will be a strang with a hoop on it. Give it a yank and the door will open. Look for an article of clothing stuck in the door.
  • Dan Webster
    Dan Webster Feb 19, 2009
    Why you low rating me I don't need your money. You open the access panel and grab the string and open the door manually. You want a repair done for 5 bucks? What did Forrest Gump's GF say? Are you stupid or something?
2 Suggested Answers
  • 44 Answers
SOURCE: CONTROL LOCK LIGHT ON. CANN'T USE WASHER.
pull plug wait 5 minutes then plug back in go into diagnostics
close door
push control/on
select drain/spin
select no spin by pushing spin speed touch pad
push prewash optionj four timesw within 5 seconds
c:00 will light up
in order to advance to next step
push prewash option 2 times
if it does not enter diagnostics you must replace main control board
Posted on Mar 12, 2009
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    Controls locked
    The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
    Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
    The "Control Locked" light is
    Mar 31, 2011 | Washing Machines
    On My Whirlpool Duet Model# GHW9150PW A setting kicked on that
    May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Control locked
    Hold the control lock button down 5 seconds and it should unlock.
    May 15, 2010 | KitchenAid KHWS01PMT Front Load Washer
    CONTROL LOCKED LIGHT ON (WASHER AND DRYER)
    The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
    With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, by leaning against the control panel, or from playing with the control buttons. This is usually not an indication of a washer malfunction.
    If this is a Whirlpool Duet series, the following link explains how to lock/unlock this feature:
    http://www.fixya.com/support/r3608801-control_panel_lock
    These instructions are printed on the front panel of the appliance and in the owner's manual.
    If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope you find this information helpful.
    Apr 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
    Locking controls
    lit, all buttons are disabled. You can lock the washer while it is
    operating.
    Select and hold END OF CYCLE SIGNAL for 3 seconds.
    Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Control Locked
    Locking controls
    operating.
    Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
    Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    41 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
