Question about Olympus RS 25 (147035)
RS-25 foot pedal not working
I installed the Olympus DSS Player version 6.3 and the dictation that I imported from my computer worked perfectly. I was able to stop, forward it etc through the screen but when I attached the RS-25 foot pedal the dictation can't be controlled through the pedal. The foot switch setting in tools is grayed and can't be accessed. I don't know if I installed the wrong software. I've been trying everything for hours now and still nothing. Please help.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
The foot pedal needs to be plugged in before the software is installed. Just uninstall the software (your files will be fine) and reinstall with foot pedal attached.
Posted on Feb 17, 2009
Had the same problem and it need a different serial number for the pedal feature to be active. They told me this was the plus software. I called Olympus and they gave me a new serial number that worked. Uninstalled and reinstalled with new serial number and alls good now. Hope this helps....
Posted on Aug 03, 2009
Can't get the footswitch RS-26 to work with Windows 7
If you have version 6 installed.
Download version 7 and all its updates which is a free upgrade then simply goto help and updates
do the updates for version 7 and hey presto the foot pedal will work.
Jul 14, 2011 | Olympus DSS Player 7
I installed Olympus DSS player (version 6.3) on my HP with windows vista home premium OS. The DSS player works fine, but I am not able to use the corresponding RS25 foot pedal with it. Please help!
Possibly you just need a footswitch driver. Here's a download for one:
http://user-guides.co.uk/download/olympus/olympusrs/olympus-rs-28-footswitch-driver.html
If you find a version 7.1 upgrade, be cautious about it, since I read that it often causes problems (google Olympus DSS version 7.1 upgrade and read about it).
Hopefully the driver will get you going.
Good luck, hope this helps, and thanks for using FixYa.
Sep 03, 2010 | Olympus RS 25 (147035)
Software not compatible with Vista
Try running in compatibility mode for the program. Go to the program thru Start menu, then right-click. There you will see the compatibility mode Tab or choose properties.
Jul 30, 2009 | Computers & Internet
RS-25 & RS-27 Foot Pedal not working with Vista x64
I had the exact same problem. Per Olympus you have to buy the RS 27 foot pedal. It IS compatible with Vista 64bit. RS 25 which is what I have IS NOT compatible with Vista 64bit.
Cheapest I found online is $43+ shipping for RS 27 foot pedal.
There is a free upgrade to DSS Player 7 on Olympus website that you will have to do for it to work with RS 27 foot pedal.
Jun 05, 2009 | Computers & Internet
Olympus AS-2000 Dictation Kit - Foot switch doesn't work on Vista
HTML clipboard Olympus AS-2000 is not Vista compatible, you need to upgrade your software, I am not sure which version you have, but I think its version 6 ? You need to upgrade your software from version 6 to 7 (free) and then from version 7 to Standard (also free ) . check your foot pedal if it's RS-23 ( check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if you have the RS-25 or RS27 you are ok .
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Hope this will help
Joseph
Feb 09, 2009 | Olympus AS-2300 PC Transcription Kit
No disc
You can download it here at this site.
http://www.olympusamerica.com/cpg_section/cpg_downloads.asp
Good Luck
Please Rate FixYa!
Dec 19, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus AS-2300
The new DS-5000 SW has still got some quirks. The RS-25 is no longer available and I too have had issues with the 27. If your PC has a serial port try the serial plug, I know it is a step backwards but it has worked for me several times. Hope this helps. For now I steer clear of the DS-5000's.
Jul 13, 2008 | Olympus DS-40 Digital Voice Recorder
Foot pedal
Make sure you are installing the Transcription version of the software not the Dictation version (Transcription version serial number starts with RTM and dictation starts with RDM). The foot pedal will not work with the dictation version of the software.
Feb 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Foot switch will not respond.
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
Bingo
Feb 13, 2008 | Olympus AS-2300 PC Transcription Kit
Olympus RS 25 (147035) Logo
3,404 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
