Question about Dell Inspiron 531s Desktop Computer
Error code 5300:0119
Inspiron 531S will not boot up. Gives error Windows has detected a problem and is shutting down....I ran system diagnositcs and get failures with error code 5300:0119 and various Video Modes.
Is this an indication of a bad video card, or is there something else I can check ? Thanks.
  • rroy1 Feb 17, 2009
    Thanks for the suggestions...I haven`t been able to get to safe mode, but will try the boot from system disk and R....
  • 2,229 Answers
Can you start it in safe mode? If so, try to do a system restore.
Next do a start>run>sfc/scannow to see if there are any system files messed up.
Can't start in safe mode? Then try to boot from the system disk and at the first prompt to do a repair type "R". Then run chkdsk /r to see if this solves the problem. This will fix bad files.
Still out of luck? Then you are looking probably in the right direction when you suspect the video card.
Posted on Feb 17, 2009
Code 80070005
This error mostly appears due to windows update. If you are trying to update windows error then this microsoft link can help you:
http://answers.microsoft.com/en-us/windows/forum/windows_other-windows_update/cant-install-win-7-sp1-error-code-returned/c8c38825-e838-46c3-940e-417e0a7cb47a
Also use a system utility software like RegInOut to fix such kind of windows errors.
Dec 24, 2011 | Dell Inspiron 531s Desktop Computer
Dell inspiron 1545 Laptop computer is getting BSOD on boot, when first ran diagnostics got error: Hard Drive - DST Test Results - Fail Error Code 2000-0142 Msg Hard Drive 0 - self test unsuccessful status...
The error indicates that there's a hard drive issue. If it just happened after the hard disk is reinstalled, remove it and reinstall it. It could be a problem caused by loose connection or improper connections. If the same problem repeats, install the hard drive on another system (to verify whether it works on another machine or not and to confirm it still works). If it doesn't work on another computer/system then your only option to run the system is replacing the hard disk. If it works on another computer or if it's detected on another system, then there could be problem with the hard disk, eg. Corrupt Partition, Windows Corrupt etc....
First of all, try booting into Safe Mode. You have to press F8 during the startup to go into Advanced Boot Options. Once you are in the Windows Advanced Boot Options, select Safe Mode using the up and down arrow keys on your keyboard. If it still doesn't work, it's the hard disk issue. Try with another Hard Disk.
But if in case you can boot into safe mode, check the Hard Disk for errors. In other words, run Windows Checkdisk utility. Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Oct 10, 2011 | Dell Inspiron 1545 Notebook
Dell inspiron wont boot windows..I have ran a pre boot system assessment build 4118... I am getting the error code 0142. msg error code 2000- 0142 please help
That error is normally a bad hard drive. Replacement is fairly easy and not to expensive, but you will have to reinstall a Operating System to the new drive.
Jan 27, 2011 | Dell Computers & Internet
Inspiron 531s will not boot up, keeps beeping, saying it is in power save mode. How do I fix the problem
System Beep Codes The Inspiron™ 531 / 531s system can emit a series of beeps during start-up if the display cannot show errors or problems. These series of beeps, called beep codes, identify various problems. One possible beep code consists of repetitive three short beeps. This beep code indicates the computer encountered a possible system board failure.
The series of beeps has a 3-second delay before it repeats. The series and delays continually loop until you press the power button.
Code Description Suggested Remedy 1 BIOS ROM checksum in progress or failure System board failure; covers BIOS corruption or ROM error 2 No memory modules detected
  1. If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  2. If available, install a good memory module of the same type into the computer.
  3. If the problem persists, contact Dell.
3 Chipset error (North and Southbridge chipset, DMA/IMR/Timer Error for Intel® platform); chipset error System board failure. Power LED is blinking amber. Time-Of-Day Clock test failure Gate A20 failure Super I/O chip failure Keyboard controller test failure 4 RAM read/write failure
  1. Ensure no special memory module/memory connector placement requirements exist.
  2. Verify the memory modules you are installing are compatible with the computer.
5 Real time clock failure. Possible battery failure or system board failure.
  1. Replace the battery.
  2. If the problem persists, contact Dell.
6 Video BIOS test failure Video card failure 7 CPU cache test failure Processor failure
Oct 06, 2010 | Dell Inspiron 531s Desktop Computer
2000-0146 error and oxc0000ed
Hard drive failure. If the system is under warranty, contact Dell for a replacement drive. If not under warranty, you can get a new drive here:
www.newegg.com
Jul 28, 2010 | Dell Inspiron 1501 Notebook
I have a Dell inspiron 531s desktop computer w/ a disc read error
Disc Read error indicated a failing hard drive. Replace the drive will be the fix, then reinstall Windows
Oct 28, 2009 | Dell Inspiron 531s Desktop Computer
Dell Inspiron 531s Desktop Computer   Logo
801 people viewed this question
Alun Cox
