Question about Intel Ethernet 10/100 Network Adapter
Ethernet network pro ve 10/100 has no link
Did a hardware diagnostics on it and everything is fine
won't obtain ip address automatically
    Problem Solver:
  • 8 Answers
Please verify your operating system.
If XP, please go to administrative tools in the control panel and confim that DHCP is enabled under services.
Posted on Feb 17, 2009
Possible ip conflict
Sounds more like a bad ethernet cable or bad port on the Iomega. Try using a different cable
Jul 20, 2017 | Iomega 1TB Home Media Network Hard Drive...
Im with virgin media and have a super hub. the internet will work wirelessly but i cannot connect my pc via a cable. the service provider thinks my onboard network adapter is not working but its new and...
Change the fixed IP address of your machine to DHCP.
If you are running Windows then
- Click Start, Control Panels
- Depending on which version of Windows you are using, look for Network and Internet
- Right click the connection you wat to change (in your case, choose the ethernet)
- Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4)
- To obtain IP settings automatically, click Obtain an IP address automatically, and then click OK.
That should resolve your problem
Jul 18, 2011 | Computers & Internet
I have an Internet Connectivity problem which I believe was caused by resetting our D-Link WBR-2310 router. We have a strange, perhaps illogical network setup in our office. Although it was set up before...
It appears you are not using the wireless connections on both the routers and the reason for using Router B was that there were insufficient LAN ports on Router A to connect to the two workstations that are connected to Router B.
To simplify your network, I suggest you replace Router B with a network hub or ethernet switch and connect the two workstations to this network hub/switch, then configure these two workstation to Obtain an IP address automatically. Router A will then issue IP address to these workstations via the network hub/switch.
Jul 09, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Jul 09, 2011 | Computers & Internet
My Toshiba Satellite Pro U400 has stopped connecting to the internet. Connectivity docotr says IP address needs to be set/was not set properly. Not my internet connection because other computer in the...
Your Toshiba Satellite Pro might be using a specified IP address. Try to set it to obtain an IP automatically. Depending on the Windows OS, whether it is XP, Vista or Windows 7, go to your Control Panel then Network connections or Network Sharing Center and double click on the Local Area Network connection (if your are using wired) or Wireless Connection. Look for the TCP/IP protocol and make sure it is enabled as "Obtain IP address Automatically" and "Obtain DNS addresses automatically". Then click OK to save settings.
Should you need further assistance, please let me know. Thank you for using FixYa.
Jan 31, 2011 | Toshiba Satellite Pro U400-S1001V Notebook...
I am connected to verizon fios and then wired to a 8 port linysis to my office. I can not connect Now. It's been working fine for months. Now I get a yellow triangle. Limited or no connectivity
Let's check some settings for the network connections. Click on "start" - "settings" - "control panel" - "network connections".
First we'll check the ethernet connection. Right click on "local area connection" - "properties" - choose "Internet protocol (TCP/IP)" - "properties". In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically".
Click on OK at both windows.
Now we'll check the Wi-fi connection. Right click on "Wireless connection" - "properties" - choose "Internet protocol (TCP/IP)" - "properties". In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically".
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 18, 2010 | Linksys EtherFast 10/100 16-Port Workgroup...
My Asus Eee net book is stating that it has "Limited or no connectivity" even when the ethernet cable is plugged in. I changed out cables thinking it was it. My other computer works just fine on the...
Assuming that you have Windows XP, let's check some settings for the network connections. Click on start - settings - control panel - network connections. First we'll check the ethernet connection. Right click on local area connection - properties - choose Internet protocol (TCP/IP) - properties. In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically". Click on OK at both windows. Now we will chect the Wi-fi connection. Right click on Wireless connection - properties - choose Internet protocol (TCP/IP) - properties. In case of not at automatically settings click on both buttons to "obtain an IP address automatically" and "obtain DNS server address automatically".
Click on OK at both windows and check for the results.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 18, 2010 | Computers & Internet
192.168.0.30 for DWL G710 does not respond
hi r_raiche
1. Take a regular ethernet cable and plug it into the ethernet port of your computer
2. Plug the other end into ethernet port of the DWL-710
3. On your computer (assuming you have Windows XP Pro with the NON-classic start menu), go to Start > My Network Places
4. On the top left under "Network Tasks" click on "View Network Connections"
5. Right click on "Local Area Connection" and then down to "Properties"
6. A pop-up window with 3 tabs should come up. Under the "General" tab, there is a list of icons with checkmarks next to them. Highlight the "Internet Protocol TCP/IP" on and click the "Properties" button underneath
7. Tick "Obtain an IP address automatically" and "Obtain DNS server address automatically"
8. Click on "OK" then "OK" again
9. Open up Firefox (or IE) and type 192.168.0.30 into the URL field
10. Type in the default username and password
Jul 07, 2010 | D-Link AirPlus G Wireless Range Extender...
Not showing the network ip address. Note i changed it from 192... to 172... and now trying to go back to the 192.168... network
Set the camera to "automatically obtain an IP-address".
Connect the camera, via an Ethernet network cable, to a router.
The router will supply a valid IP-address to the camera; much simpler than trying to "manually" set an IP-address, network-mask, and gateway IP-address.
Dec 08, 2009 | Veo Observer Network Camera
Why won't my satelite modem communicate with my ethernet connection in my systemax venture computer.
hi there,
have you check your network connection,try to go control panel, check if you a network connection,check the driver of your ethernet on device maneger,if no driver install your lan installer,if your network is working properly,on network connection left click
local area connection properties.click tcp/ip,click properties and
type on the box your ip address manually example 192.168.0.1 and click that no. on the box to get your subnet mask,then close all until you get ip address manually,checking ip address on your network check on status,if you got manual ip address,then back again to network connection this time obtain your ip address on tcp/ip properties click obtain an ip automatically from modem,
besure to connect your modem on lan port.regards
Jul 04, 2009 | Systemax Computers & Internet
Intel Ethernet 10/100  Network Adapter Logo
166 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
