Question about Canon CanoScan 4200F Flatbed Scanner
Email scanned docs
I hooked up the scanner and am able to scan and email docs as a jpg attachment. How can I get the scanner to scan and email in pdf format.
I thought it was using the front buttons, but haven't been able to get it working.
    Master:
    Sergeant:
  • Canon Master
  • 382 Answers
I find another free online ocr to convert image to text, it supports 40+ languages, and can save converted text to editable txt file and searchable pdf document.
Posted on Dec 05, 2015
    President:
  • 2,692 Answers
You don't. Scanners save everything as a Picture. Test is not text, it is a combination of thousands of dots that make up a picture. It takes an OCR and very complicated software to read text from a picture.
Posted on Feb 17, 2009
I2400 scan to email doesn't work
You must have an email program like Outlook installed on your computer. When scan to email is selected it simply opens whatever defaul email client and attaches the scanned doc to a new email message.
Sep 24, 2014 | Kodak i2400 - document scanner
Word docs sent as email attachments are arriving in my inbox as png files - useless. How do I change this please
.PNG stands for "Portable Network Graphics". Sounds like the sender may have scanned the document, and sent the scanned document to you? Scans will come out as either .png, .jpg, or .pdf formats.
If the file is a .png, you won't be able to edit in MS Word.
Another thing to check - Make sure when you are working on a Word Document, you are saving it as a .doc file.
  • Open MS Word Document
  • Do your editing
  • Click on the "Fille" button, and then select "save as" option
  • In the window that appears, next to the "save as type" wording click on the down triangle to see different formats to save. Select ".doc"
Bottom line... tell whomever is sending the emails with attachments, to send you the MS Word file, not a scanned file.
Jul 26, 2014 | Dell Inspiron Computers & Internet
Brother HL-2280DW scanner won't attach to an email
If you are attempting to attach the file as a .jpg or the like (an image file), it is likely just too large for your email client. Try backing the resolution of the image wayyyy down, it should "bite" and attach if it isn't so large a file.
Jul 20, 2014 | Brother HL Office Equipment & Supplies
HI CAN YOU TELL ME HOW TO SCAN A DOCUMENT ON THE CANON IRC3220N PRINTER TO ENABLE ME TO EMAIL
Scan the document and save the document as a jpg image file then create your email and attach the jpg image file as an attachment to your email before you send the email.
Aug 24, 2011 | Canon Office Equipment & Supplies
When I go to scan a doc to e-mail I get an error message that says (Not Set Up on PC) and I am unable to scan and send a doc via e=mail
Well as a workaround, as long as you can actually scan and save ... What you do is scan what you want, save it, then either save it as a PDF OR convert it to PDF After which you can then "Attach" it to any email you wish. I recommend PDF as most people have Adobe Reader.
If you can't scan to PDF, and it only saves as say JPEG, then get DoPDF http://www.dopdf.com/ To convert it from JPEG, JPG, BMP etc.
Feb 03, 2010 | HP LaserJet 3050 All-In-One Printer
How do I scan several pages to email
Create a directory called Scans on your C drive
Scan each of your images and save them as a.jpg or whatever to the Scans directory.
Open a new eamil go to the top bar and hit Attach
Navigate to the Scans directory then hold down the shift key and click on the files you want to send
Hit Attach and they will appear in the box on your email
Send an normal
You can add picture in the same way , just make sure that you place the cursor where you want each picture to show on the body of the email
Jan 25, 2010 | HP ScanJet 2400 Flatbed Scanner
HP 5590 - cannot scan and save doc directly to jpeg format
I need the scanned documents be saved as pdf in HP scanjet 5590
Apr 27, 2009 | HP 5590 ScanJet Flatbed Scanner
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Canon CanoScan 4200F Flatbed Scanner Logo
139 people viewed this question
old marine
old marine
