Question about Kenmore Elite 45986 Front Load Washer
Installation after moving/ water not going in
We just installed the washer after moving in. When you turn the washer on, the water goes through the hoses into the washer, but instead of going into the washing compartment, it comes out another vent in the back and runs all over the floor. What have we done wrong?
  • Dan Webster
    Dan Webster May 11, 2010
    Is the drain hose properly connected to drain?
  • 360 Answers
In order to move one of the new front loading machines, the shipping bolts/supports that originally came installed with the unit must be in place to prevent damage. At this point you can attempt to make repairs yourself or, if under warranty, calling a authorized repair center for repairs. The warranty will not cover damage due to moving the machine without the bolts/supports, however having a authorized service center make the repairs will keep the remaining warranty intact.
clarkco
Posted on Feb 17, 2009
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Need to remove and replace electronic water valve
First off unplug washer.
Turn water off hot and cold.
Disconnect water lines from valve.
Remove screws from top panel on washer then slide top panel off.
Remove connections on valve. Make mental note for what goes where. ;)
Remove valve.
Install new valve.
Connect wires.
Put panel back on and screws back in.
Connect water lines hot for hot and cold for cold.
Turn water on and check for leaks around connections.
Plug washer in.
Run a load!
Hope this helps.
Oct 26, 2012 | GE WBVH6240F Front Load Washer
I wont to replace the sealant from around the tiolet waste pipe, what is the best way of doing this?
turn water supply off to toilet and disconnect water line from bottom of toilet tank. flush toilet to drain tank, use towel to soak up water inside that didnt flush.remove the 2 bolts ( 1 on each side of toilet), lift toilet up and move to one side and lay on it side, scrape off old wax ring from bottom of toilet, scrape off excess wax from pipe on floor. install new wax ring over drain pipe. stand toilet upright and lift straight up over drain hole and reset slowly to make sure each bolt goes through the holes on toilet, replace nuts and washers on toilet and tighten. hook water supply liune back up and turn on water.
Aug 30, 2011 | Home
Just recently moved & had washer in storage for about 4 months during summer. The washer will add necessary water then just as the wash cycle is about to start it goes from 38 minutes to 4 minutes on...
does it drain the water??? most coommon prob with this unit is faulty pump/ item in pump preventing proper drain, if it thinks theres water in or too much water in it will automatically try to drain and do nothin else, drain motor might have siezed form sitting as well, that why yo ned to check to see if water is actually draining out.
Oct 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
After moveing washer it will not srart . It was turn on it side when it was moved.
Hiya,
after movining a machine the most common reason for them not to start after re-instalation is the water supply, almost everyone forgets to turn the water supply to the hoses back on after re-connecting the hoses so this would be your 1st point of check..
hope this helps
Apr 21, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer goes to agitating mode when turned on . water does not start to fill when turned on.
Water level pressure switch is jammed. This 70mm round sensor has a thin flexible pipe going into it and some electrical wires connected. Disconnect power and check centre plunger moves freely.
Feb 27, 2010 | Washing Machines
New machine - cannot get it to start - when i go through sequence as manual, choose programme options etc, then press start, top light in sequence goes orange instead of green and programme does not start.
Have you remode the transit screw ./ bolt? Does the drum turn freely by hand - it should. Is the water supply turned on and connected to the machine? If not the machine will not work. Also make sure that the door is firmly closed. If these are OK then switch off the machine at the mains and wait for 30 mins then switch it back on and try again.
Sep 30, 2009 | Hotpoint WMM39 Front Load Washer
Sealer that goes around the tub to keep th water
part is $115 list (cost is less for techs). I have posted instructions on other posts. install is fairly easy. little work involved
Mar 30, 2009 | GE WBVH6240F Front Load Washer
The washer goes everywhere and is very loud
Try putting a cup of water on top of unit and stand in front and bounce up and down if water moves in cup floor is weak not strong enough for unit.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
85 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
