How do I remove the fuser unit from the Xerox XD100 workcenter? I replaced the pinch roller in the fuser 6 months ago. It was very difficult but it worked. I'd like to know how to actually get the fuser out and dissassemble it to check the gears etc. I'm getting the loud noise but it still makes copies. It sounds like it is coming from the right front of the unit. I have wondered if it could be the gears in the drum unit. Thank you
    President:
  • 2,976 Answers
Directly from the service manual.
The useful life of the drum cartridge is approximately 18,000 copies. The
drum cartridge indicator on the machine diagram lights when the drum is
near the end of life. Approximately 1,000 more copies can be made, but
you should have a replacement cartridge in stock. When the J2 Status
Code is displayed, the machine will stop operating until the drum cartridge
is replaced.
Note: Ensure that the alternate paper tray
is lowered (XD104/105f/130df/155df only).
1. Press the release lever to open the side
cover (A).
2. Press the front cover release buttons to
open the front cover (B).
3. Press the green button (C) on the front
of the toner cartridge and pull out the
cartridge.
Note: The toner cartridge must be
removed before removing the drum
cartridge.
4. Pull out the drum cartridge.
Note: Help the environment by recycling
your used drum cartridge. Refer to the
recycling brochure packed with the drum
cartridge for details.
5. Remove the cover from the new drum
cartridge.
CAUTION: Do not touch the shiny surface
of the drum.
6. Slide the new drum cartridge in place,
making sure not to touch the surface of
the drum.
7. Reinstall the toner cartridge.
8. Close the front cover and the side
cover.
Posted on Feb 17, 2009
    Scholar:
  • 52 Answers
Ok so how to remove the fuser, disassemble, get to gears..
To access wires/connectors remove back cover 4 screws then open and remove right door 2 screws on back frame one with small spring attached. Then remove fuser unit with 2 screws unplug 3 connectors on back of copier.
Now remove one screw on wire end of fuser/cut ty wrap with wire cutters be careful not to cut wires!!
Pull off cover and remove heat lamp by pulling on copper end piece
slide lamp up and out. Remove small c shaped retainer ring from end of roll with 2 small flatblade screwdrivers, take off old gear and install new one-lubricate bushings with a few drops of fuser oil on both ends re-assemble in reverse order.
Please let me know if this was of help to you:)
  • 6,487 Answers
    Brigadier General:
  • 8,619 Answers
Hi!
for removing fuser unit you need to open the front cover of the unit, then using a philips screwdriver you can remove it
  • Rylee Smith
    Rylee Smith Feb 17, 2009
    To replace the gear you will need to remove a retainer clip and then unclip the fuser bulb to slide the gear into place.
  • Rylee Smith
    Remove the back cover also and then pull off the cover by removing the retainer clip and remove fuser bulb(heat lamp) by pulling on the end piece.
    Now you will be able to see the gears which can be removed by detaching the retainer ring from end of roller.
    Thanks
    Rylee
Workcenter pe 16 open heat error
Bad Fuser. Google a business called The Parts Drop to order.
It is not difficult to replace. Remove the back cover, 4 phillips screws pull out slide the new one in.
I would remove the fuser first though. And check the plastic in the ends of the fuser. If they are melted, then the power supply has failed and you will have to replace both the fuser and power supply. If the fuser looks normal no plastic on the end of the rolls melted, then just replace the fuser.
Mar 12, 2011 | Xerox CopyCentre C20 Black and White...
I have a xerox workcenter XD102 with a J1 error. What do I need to do?
J1 code on the XD100 series means that your toner cartridge is empty. You will need to order in a new one or have your existing cartridge refilled. Refills run about $60.00 and new ones are in the $100 to $125 range.
Precisionroller.com has a very good remanufactured unit for $46.00
http://www.precisionroller.com/search.php?q=xd100+toner
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Jan 25, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Workcentre XD100 Accordion Jam After A Few Copies
What is most likely happening is the pressure and heat roller bearings and bushings are very gummed up.
When you remove a the fuser when its cold, try turning the heat roller gear, I would assume it is very very tight to spin.
What you can do it take the fuser apart, soak the pressure ( soft roller) roll bearings in some alcohol and then clean the heat roll ( aluminium) roller bushings and the end of the heat roll. Make sure you lubricate with some silicon lube the ends where the pressure roll mounts into the small holes in the nip fingers. That should help.
You can call a business called , ( you can google, The Parts Drop) and talk to Britt there. I am pretty sure he has the bearings for that machine. I don't work there, just have done business with them for years and they are top knotch.
You probably want to replace the gear also. Sometimes it can look really good, but be worn just enough to cause a problem.
Make sure you take a real good look at the condition of the rollers before you spend money replacing small parts, so that you don't wind up replacing 40 or so dollars worth of parts only to find out you do need the entire fuser.
Nov 29, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
XEROX WORKCENTER XD100 NOISE
Most likely the fuser gear is worn. The noise is prominant in the right side toward the back I am assuming.
You can replace the heat roll drive gear itself, but honestly I would recommend replacing the entire fuser assembly. It is probably very very tight and would wear another gear out quickly.
You want to get that replaced before the drive gear on the main motor assembly wears out. It would not rewuire replacing that entire main drive assembly, But it is a real difficult part to replace.
Go onto google and do a search for The Parts Drop. It will be the first item to come up. CLick it on and call and talk to Britt.
He will have what you need for a reasonable price.
if you go that route and need instructions to replace that part. let me know. Its not very difficult.
Jul 16, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
XD100 Workcenter Copy quality
If its is a fine line. Looking like a pencil line. See if it is there when you run it off the glass or through the document feeder. If it is only there when it is run throught the document feeder, the small strip of glass under teh document feeder had some contamination on it.
You may have something on the optics. Mirror or lamp carriages. You would want to clean those. The Drum cartridge could be bad. Take the drum out and see if it's on the drum.
The transfer wire on the lower part of the right hand door, just above the white rollers and may need cleaned.
Last and the least likely would be the fuser roller. That is the heated area just before exit area of the machine, You can look in there with a flash light and see if any of that roller is worn.
In order, I would think . 1, Drum, 2 Optiscs, 3. Fuser,4 Transfer corotron wire on the right door.
Mar 17, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
35 people viewed this question
k24674
jasbo
jasbo
