CHANNEL 47 AND UP ARE BLURRY AND NO VOICE
I MOVED MY TV FROM ONE ROOM TO ANOTHER. I HAVE CABLE IN BOTH ROOMS. WHEN I MOVED THE TV I SET UP THE CHANNELS AND IT GOES FROM CHANNEL 2 TO 125 BUT WHEN IT GETS TO CHANNEL 47 IT IS BLURRY AND NO VOICE.
    Novelist:
  • 184 Answers
Try it again in the original room where the TV once was. If the channels from 47 and up are back to normal, its a cable signal issue that the cable company must resolve. Its possible that the installer may have driven a staple thru the coaxial cable or did not correctly attach the fittings.
michtech
Posted on Feb 17, 2009
Poor reception on some digital channels
If possible either move the set to a room with no reception issue to see if same there or move another set to where this one is.
Usually a set does not have a problem if only certain channels.
Swap the set(looking for loose or damaged connection where cable crimps to fitting) if you can.
Mar 19, 2012 | Televison & Video
I hav a duodvr 625 but its olny working for one tv how do i get it to show up on the other tv?
I will assume it was installed to two rooms when installed otherwise it will need to be wired to the second TV.
If it was indeed installed to two TVs at the first tv location with the TV1 remote press MENU-6-1-5. You should now be at the modulator set up screen. Note what channel TV2 is modulated to generally 60 air or 73 cable.
Now go to the TV2 location and run a cannel search. If it does not find the channel go back to tv 1 and change the TV channel to the opposite setting of air or cable based on what it was previously set to and try the channel scan at TV2 again.
If it still does not pick it up then most likely it is not wired for that room.
If the receiver was installed to one location Dish will need to wire the second location for you in order to achieve the desired outcome.
Thanks for using Fix Ya and being a valued Dish Network customer.
Mar 24, 2010 | DISH Network DVR-625 DTV Receiver /...
ON CHANNEL 47 THERE IS A BLACK SCREEN WITH DATE, TIME AND LID://T
Check the closed-caption settings on the TV. It's probably set for "text" now and should be "off". In text mode the screen is blanked out to make room for the text display, but there isn't any. On many channels or programs you'll never see anything, but it sounds like your channel 47 is actually presenting something.
May 09, 2009 | Durabrand BH1304D 13" TV
My Tv suddenly will not tune to a channel
please help in unlocking my broksonic CTVG-5463GVC
Jan 30, 2009 | Broksonic CTGV-5463TCT TV
Repost: some channels missing.
try going as high as the channel will go taking time to see if there is a picture on each change
Dec 08, 2007 | Mitsubishi CS-27205 TV
Some channels missing...
Try to tune the tv in manual search method. If you get means store it manually. Nothing to worry. This is due to malfunction in AUTOMATIC FREQUENCY CONTROL COIL weak. Even you won"t get channels in manual tunning method. Change tuner and afc coil. Problem solved.
Sep 04, 2007 | Mitsubishi CS-27205 TV
Dim and blurry
try adjusting the focus control located on the flyback of the tv. good luck
Jan 31, 2007 | GE 32GT740 32" TV
Toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Jan 21, 2007 | Sony KV-36XBR250 TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
