Question about Poulan Garden
14in.poulan willnotaccelerate hard to start but will finally but will not accelerate
  • John McKinney May 11, 2010
    Try taking the cover off and looking at the throttle cable. I have had them broken before. let me know if this is it.
  • Thomas F. Schneider May 11, 2010
    High speed jet inside of carb is blocked?Spark advance not working?
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Where can i order a handle for a 14in Pullan gas
A few days ago i would have you here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html (poulan's part outlet)
They have locked the site to non dealers. Please go here:
http://www.poulanpro.com/node4020.aspx
To register your displeasure. They should be willing to help you with their product.
It used to be fairly simple to find parts. This new system will hurt their sales IMO. Tell them that! HTH
Lou
Posted on Sep 27, 2009
jrox55
  • 66 Answers
SOURCE: poulan pro 220 chainsaw owner's manual for tune-up
you could try cleaning the carb and filter. make sure your fuel lines are clean too
Posted on Feb 27, 2010
What could cause chainsaw not to start. It's not getting fire to the plug
If there is no spark it could be an HT wire or the magneto or the magneto grounding switch.
Oct 14, 2014 | Poulan Garden
1992 pajero auto temp light stuck on when motor wasn't running long when accelerating vehicle stopped then hard to start now won't start at all,
Sir if the starter is not even turning im sorry to inform your engine might be broken. Lack of oil could be the reason. I d reccomend to send to a mechanic shop inmediately.
Jul 12, 2014 | 1995 Mitsubishi Montero
1993 Mustang 2.3L Trouhble(again); It's slugish at accelerating from a stop(some times falling on its face and dieing), jerks at highspeeds when trying to accelerate, and has hard starts. Any help
All the above problems were happening to my truck, and the engine light never did come on. Finally changed the O2 sensor, and it runs like new again.
Mar 30, 2013 | Cars & Trucks
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I cannot find a replacement chain for Poulan 1514 chainsaw 1.5 hp 14"
Poulan PLN 1514 uses a 14in S-49 chain that is made by Oregon, the original chain has a part number 966-051501 that does cross to anything but the original has 49 drive links and S whith on the bar. This is available on Amazon for about $13.00 with postage Retail stores are charging over $20.00 for the same chain
Oct 26, 2010 | Poulan Garden
Hi I have a Poulan 3000 chainsaw that starts hard and wont stay running. Does anyone have a sevice manual? I am not sure where to set the carb adjustment screws to start (idle, low, high).
No service manual, but you should check the fuel filter, air filter, and muffler for plugging. Check the condition of all of the fuel lines looking for decay or other damage. Chances are that the jet screws are 'D' headed and can't be adjusted by the owner, only an authorized service shop has the necessary screwdriver. Be sure to have fresh fuel mix in the tank and be sure to shake the fuel can just before filling each time to prevent oil starvation. Don't make up more than a gallon at a time unless sawing is your business. Hope this helps!
Oct 18, 2010 | Poulan Reconditioned Chain Saw 33cc 14in...
Poulan.com
Lou
Sep 27, 2009 | Poulan Garden
Poulan Pro weed eater won't accelerate.
check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
HARD TO START CAN'T ACCELERATE
Have you done any work to the carburetor?Sounds like the carb. is dirty and needs to be cleaned. you may also need a carb. kit, depending on how old it is. If you need further assistance on how to do this, feel free to ask.
Jim
May 29, 2009 | Poulan PP4218AV 18" Chain Saw
Garden Logo
91 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
