Need replacement gears - Destroyit 2602
Unit was dead - no power. Spent an hr taking it apart. Some teeth on large gear (2 total gears) broken. Removed the broken pieces and put back together. It now moves for 2 seconds and stops (can shred, but takes forever), so I want to replace the gear. Is there any merchant that sells replacement gears for this unit?
Thanks!
  • Tom  Vinson
    Tom Vinson May 11, 2010
    This is how a got my hard to fine gear!
    Contact Michael Business Machines for your local dealer 1-800-223-2508
    Good luck, Tom
  • anthonyzig May 11, 2010
    I have the gears but I will need to know the the following.
    2602...any letter (s) following?
    serial number?
    Thanks
    Genius:
  • 1,218 Answers
If this is a Royal shredder give them a call at 1-800-524-0799 for parts assistance.
Posted on Oct 19, 2010
We have a destroyit 2602 cross cut shredder, when we put the paper to be shredded in, the shredder would go on automatically, now that does not hapeen. we have to manually press the on button.
The paper sensing switch lever has bent or broken or the switch is faulty. Check between the wheels about in the middle of the shredder to see if you see if the little plastic finger. If the finger is visible and can be moved, the switch is faulty. REMEMBER TO UNPLUG IT BEFORE DOING ANY INVESTIGATION.
Feb 20, 2011 | Destroyit 2602 Shredder
We have a model 2602 that jammed pretty badly. After unplugging we pulled out all the paper we could from both top and bottom and turned it back on. Now the motor runs but will not pull paper through. Is...
Check to see if both the upper and lower blades are turning. If the motor is running and the blades are not turning, then it is probably just a broken gear.
Feb 17, 2011 | Destroyit 2602 Shredder
Destroyit 3102 drive gear part number
The part number you need is 2601 062 as long as your looking for the gear that meshes with the motor shaft. The price is around 25.00 dollars and phone number for destroyit or as known MBM corp. 800-223-2508
Hope this helps leave feedback if so. If you have trouble getting part contact me i'm a dealer and can get you the part.
May 14, 2010 | Destroyit 3102 Shredder
Gears won't turn in forward like a gear or shear pin is broken looking for a service manual
The plastic gears on either side of the drive motor have the teeth sheared off. I just have to find somewhere to buy the parts.
Dec 01, 2009 | Destroyit 4002 Shredder
RE; Durabrand Paper Shredder. Model Number WM6X. The motor works in reverse mode only, but the blades don't turn, Help
You have broken gears. Call customer service at 800-327-8508 and they will send you 2 gears for $10 including postage. I got mine in less than a week. Easy install.
Nov 05, 2009 | Office Equipment & Supplies
Makes clicking/grinding noises when printing. just replaced drum but that didn't help. any ideas on what it could be? sounds like a gear perhaps?
Most likely, the gear in the fuser assembly is cracked. That is the most common problem with that unit. You can take the fuser out to examine if the gear is broken or partially broken before deciding to replace it. Lastly, check to see if the noise is happening at the rear of the printer, thats where the fuser is located.
you will need to Replace HR Gear34 in fixing unit and the part # is LJ7416001.
here is the info to do it, but I dont recommend it.
1. Disconnect the heater harness and thermistor harness.
2. Remove the bind B M4x12 taptite screw and the shoulder screw, then remove the fixing unit
3.After the fixing unit has been removed, remove the 3cup B M3x10 taptite screws and remove the FU paper guide
4. Remove the 3cup B M3x10 Taptite screws and remove the star wheel holder
5. Remove the cup B M3x12 Taptite screw
6. Release the thermistor assembly harness from the hooks
7. Remove the thermistor assembly
8. Remove the 2cup taptite screws
9. Remove the upper FU frame from the lower FU frame
11. Remove the heat roller 25
12. Remove the halogen lamp
13. Remove the HR bearing 25
14. Remove the HR Gear 34
15. Remove the HR retaining ring 25
16. Remove heat roller washer 25
17.Check the heat roller bearing 25 for damage. If damage is noticed replace the bearing and the Hr Gear 34. The part # for the washer is LJ7414001
May 07, 2009 | Brother MFC 8820D All-In-One Laser Printer
I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Apr 05, 2009 | Fellowes PS60C-2 Shredder
Broken gear on Destroyit 2602 SMC
If this is a Royal shredder call 1-800-524-0799 for parts assistance.
Mar 26, 2009 | Office Equipment & Supplies
Royal SC800 power shredder I need the large metal gear.
I have the SC800 apart. My problem is not fixing it. I just need the part. The large gear which appears to be made of pewter has a couple of teeth missing. If I could find the part I can fix it. It's a very simple machine. If you know where I can get the part I would appreciate you letting me know..
Sincerely;
Ken Ashley
Oct 14, 2008 | Royal JS800 Shredder
Broken gear
I turned the gear arround and put it on backwards
doitdel
I still need a new gear since it is still missing a couple of teeth
Jul 15, 2008 | Cross Infoguard Shredder SX102M
458 people viewed this question
jasbo
jasbo
