Question about Acer Aspire 5100 Notebook
Programs will not open on acer one netbook.
Programs on the acer one netbook have one by one stoppped working. When I say not working I mean not opening when clicked on. There is a plug in sign on the toolbar even when its not charging, at around the same time this problem deleveloped my wifi stopped working, it says 'no network devices have been found.' I don'tknow what to do :-(
  • 544 Answers
easy don't worry what happen your laptop is just a common problem and you can fix it..
we just need to reformat you laptop Sir/Mam
Here you can follow some instruction you can do by your own.
1. Plug in the AC adapter and battery.
2. Turn the system on
3. Immediately, press ALT on the keyboard and start tapping F10.
Continue holding ALT and tapping F10 as the unit boots up.
4. A screen stating "Starting Acer Erecovery" should appear.
(Release ALT and stop tapping F10 at this point)
5. Choose Restore System Factory Default
1. Restore system to factory default
2. Exit
1. Enter the password created when eRecovery was first started.
2. Read the on-screen warning and choose Yes.
3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
Posted on Feb 17, 2009
Acer mouse is not working
If the lights are on, it means that the power supply is intact. The first thing you should do is reboot your computer.
If the problem persists, try using another mouse. If that does not solve your problem, check the mouse's drivers under device manager, (click on the start button, then select Device manager).
If there is a red or yellow mark beside the mouse, update or reinstall the mouse drivers. Uninstall from Add/Remove Programs(Xp) or Programs and Features (Vista/7).
Nov 20, 2013 | Acer Aspire One Netbook
Recovery acer5538
What is this
Do want recover your acer to factory defaults.?
or
use a usb memory card (usb drive)
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen.
The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options.
Choose "Factory Restore" to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
An example on how to safe documents , photos or data to a usb drive
Click start all programs accessories open windows explorer navigate to your photos
Right click on the documents , photos select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photo's to your usb drive then drop them
or if you are downloading data or programs from the internet
once it starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents or another device or a usb device
May 16, 2013 | Acer Aspire One PC Notebook
Delete gGrabber
You didn't give much to work with, but Open Control Panel, Programs and Features, delete program. I have no idea what gGrabber is? Do you mean vGrabber? Take a look at the: http://guides.yoosecurity.com/how-to-uninstall-vgrabber-toobar-fake-vgrabber-virus-removal-help/ Do you havea UP-TO-DATE Anti Virus? Run a full scan. Download MALWAREBYTES freeware at: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the TRIAL PRO version, you want the freeware version. Run a FULL SCAN, DELETE ALL RESULTS. Reboot. Then download CCLEANER freeware at: http://www.filehippo.com/download_ccleaner/. This will clean the junk from your machine. Also in TOOLS, Startup, disable all unnessary startup programs at start. Also this: http://answers.yahoo.com/question/index?qid=20110909151406AA3nei9
Dec 16, 2012 | Acer Aspire One AO532H-2527 Netbook
I can not get the web cam to work
Instructions1 Take pictures independent of communications software on the Windows version of the netbook by using the webcam without connecting to networking software. Click the "Windows Start" menu and click "Acer Crystal Eye Webcam" in the Programs list. The webcam application should open and the camera should produce an initial warmup image. Use the buttons on the control panel to adjust image size or take photos.
2 Use the Instant Messenger program on the Acer Linux-based laptop or netbook to work the webcam. The Acer Instant Messenger program is available in the Connect folder on the Acer laptop's desktop screen.
3 To send and receive live video and pictures using your webcam on an Acer laptop, work the webcam through individual communications software, including Skype, Windows Messenger, Yahoo Messenger, AOL Instant Messenger, or Google Video Chat. Open your selected communications software program and click the webcam button to work your webcam.
Thanks
Apr 02, 2012 | Advent Computers & Internet
Can not get the web cam to work
Please follow the below Instructions
1 Take pictures independent of communications software on the Windows version of the netbook by using the webcam without connecting to networking software. Click the "Windows Start" menu and click "Acer Crystal Eye Webcam" in the Programs list. The webcam application should open and the camera should produce an initial warmup image. Use the buttons on the control panel to adjust image size or take photos. 2 Use the Instant Messenger program on the Acer Linux-based laptop or netbook to work the webcam. The Acer Instant Messenger program is available in the Connect folder on the Acer laptop's desktop screen.
Thanks
Apr 02, 2012 | Computers & Internet
I have downloaded skype successfully onto my acer aspire netbook. where will I find it on the netbook?
You can try to search it on your computer if you're using Windows XP. Open my computer than Press Control + F type the name of the program then select the your hard drive the click on Search.
Windows Vista and Seven: Click on Start then on the lower left under All Programs or Programs just type Skype. and you'll see the installer. The next time you download a file make sure you verify the specific location where you save it.
Thanks for using Fixya.
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
My webcam does not work on my acer netbook. How
Check whether the Webcam is listed in Device manager Go to Start right click on computer click on manage , click on Device manager , In Device manager under imaging devices see whether there is webcam listed , if not install the webcam driver from www.support.acer.com, Check whether the Webcam Application is listed in All programs, if not Re-Install the Software from Acer Recovery manager Access Recovery Manager by going to All Programs ->Acer-> Acer Recovery manager -> Restore-> Restore Drivers and Applications , Select webcam software to Install
Jul 13, 2010 | Acer Aspire One Netbook 8.9" Notebook
I just bought a new Acer netbook (A0532h - Model # NAV50) from Staples. The wireless connection is fair (same as my other laptop) yet the page transitions on my new netbook are painfully slow. Any...
This device should be about 90% as fast as your laptop.
The slowness could be caused by the number of programs you have opened at any given time. The system is not really designed to run multiple programs.
It can also be caused by the excess software on the hard-drive, and its condition.
Try removing any 'demo' software and other programs that you will not use (stay away from the OS) and then run the defrag program in Windows.
Apr 23, 2010 | Acer Aspire 5003WLMi Notebook
Acer aspire one trouble logging-in.
look into the firewall for interdiction...and if you use a wireless router to connect ..ask for whom it might install it ...if restricted the access on this programs...I use to restrict from the router the access on programs like this when I was working for a company ...that had internet access on the stuff desks....
try it froma different location ...and if it works ,,,it means that the provider or the router is to blame ...but if not it means that there are restrictions into your laptop ...either from the firewall( most sure ..cause those two are separate programs ..one is an im and the other from the browser..) but ,,try to see the acces limits from the browser too..cause maybe if the interdiction is on yahoo...it doesnt allow messenger either ..
Jul 15, 2009 | Acer Aspire One D150-1587 Netbook
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
