Question about Necchi Sewing Machines
Necchi Supernova won't zigzag anymore
My Mom's zigzag on her 50 yr old Necchi Supernova won't work now. Any suggestions?
4 Suggested Answers
  • 323 Answers
SOURCE: Stitch length control knob broken on my Necchi Supernova Julia
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
Posted on Apr 25, 2009
  • 1116 Answers
SOURCE: i have an automatic supernova circa 1955. I often
When was the machine last serviced by a sewing machine tech? It could be old lubricant and dust have gummed up the gears.
Carefully warm the area with a hair dryer to see if this will loosen up the selector.
If the problem continues, the machine will need to go into the shop.
Expect the bench charge to start at about $80 just to do a routine cleaning and lubricating.
Posted on Mar 18, 2010
  • 1564 Answers
SOURCE: My mom has a Necchi supernova ultra that needs a new belt. What is the correct size and where do I find one?
Just measure the existing belt and go from there. Besides the supernova and supernova ultra are likely to use the same belt.
Posted on Sep 13, 2012
SOURCE: I have a Necchi Supernova Julia sewing machine, and unfortunately
I had what I thought was the same problem with my Necchi Supernova Julia 534. Turns out it was the needles. Buy a new package that you know are right and try them.
Posted on Dec 29, 2012
Sep 07, 2012 | Necchi Sewing Machines
Need belt for necchi supernova automatica sewing machine
You can also use a Eureka vacuum cleaner belt, can't remember the exact model, but the package says it's for most sewing machines. It's not the V belt, but it works on my Super Nova and it's 1.79 for two!
May 09, 2009 | Sewing Machines
sewman7
Apr 24, 2009 | Necchi 4595 Mechanical Sewing Machine
Need User's Guide/Manual for Old Necchi Supernova
You can search sewing machine manuals here online and find your Supernova Manual for 10-15 dollars. http://www.sewingmanuals.com/Sewing_Machine_Manuals/Necchi.htm
As far as using WD-40 please don't use that. It is not for oiling. The WD stands for Water Displacement. It was designed for automotive electrical, etc. It is also a good penetrant for loosening nuts and bolts or stuck parts.
You need to use regular real sewing machine oil (white oil) that can be found most any store or another great product is called Tri-Flow from hardware stores that has Teflon in it. WD-40 is not oil.
Nov 29, 2008 | Sewing Machines
Sewing Machines Logo
71 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Derek Massey
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
