Question about Reebok Vista Treadmill - RBTL13305
NordicTrack exp 2000 treadmill stopped working!
Gets power to board, won't power the drive motor. everything else works fine. motor when plugged to battery works. need help asap!
  • 64 Answers
SOURCE: nordictrack treadmill will not close
Check elevation position.
Posted on Jun 08, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
  • 9 Answers
SOURCE: Nordictrack treadmill C2100 belk is not slipping
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
Posted on Oct 22, 2009
  • 40 Answers
SOURCE: I have the Nordictrack Apex 4100I treadmill. It
try caibrating it.
Posted on Nov 01, 2009
  • 103 Answers
SOURCE: can you get power to a treadmill without the
Hello there. Yes you actually can use a magnet. (thats all the safety key is) It will need to be strong enough to make the switch inside the console activate. I use one from a telescoping magnet used for picking up small screws (available at the big box stores) when I dont have one on service calls.
Just to let you know a refrigerator magnet will not be strong enough!
Good Luck! Tim
Posted on Feb 21, 2010
Console does not work it lights up but no buttons function
this just happen to mine this morning, can't find a fix. Help!
Mar 17, 2014 | Nordic Track Nordictrack Exp 1000...
I own a Nordictrack 7000R and the console just quit working. It turns on like before, but now only speeds 3, 8 and 12 work...no other function operates...no start/stop, incline anything. I really love...
All electronics should have a surge protector. So when the power flickers and send a power surge to electronic plugged into the wall the circuit board is protected like your computer.
Nov 03, 2013 | Nordic Track NordicTrack Commercial 1500...
Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
Jun 19, 2012 | Nordic Track Nordictrack Exp 1000...
How do i turn on a nordictrack treadmill exp 1000 x
they have a small switch Red in lower part to the side to the power cord.
see you instruction manual, or download free www. iconservice.com
God bless you
Jun 17, 2012 | Nordic Track Nordictrack Exp 1000...
Nordictrack EXP 1000 belt runs but stops when I get on it. Drive belts are tight
1) Try to loose a little the drive belt, for to avoid a higher tension.
2) LUBE very well the deck belt, must shure is worn, proceed with the instruction manual maintenance.
3) Test the input voltage motor, if there are voltage the motor need repair
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faultyl.
See my personal TIPS for HELP.
Try to RUN THE software calibration for diagnose, and troubleshooting
sincerely. God bless you
Apr 24, 2012 | Nordic Track Nordictrack Exp 1000...
Only certain buttons on the NordicTrack exp1000 treadmill work.
1) You must check the flexible cord between display board vs controller motor board, and tight very well
2) Try to access to the keypanel and clean with special spray (clean contact you can find in radio schack or computer store).
3) Try to Measure the +5Vdc for I.C. including EPROM, ROM, etc.
4) And try again.
5) Measure if the power supply to display is coming out from the Lower board or Motor controller board. If not the Motor controller is faulty. You must replace it.
Use Dvoltmeter.
Remember 90% aprx the Motor controller board access to the function in the display board, elevation motor, power input, etc.
sincerely.
Nov 22, 2011 | Nordic Track Nordictrack Exp 1000...
I need a mannual for my nordictrack exp 10000 xI. Can you help?
Here is a list of many different versions of the NordicTrack Exp 1000XI. If you know your exact model number you can click on your version and view a parts list and purchase an owner's manual. If you just need to look at a diagram of all the parts many of the equipment pages have that available to view for free. Hope that helps.
Sep 12, 2011 | Nordic Track Nordictrack Exp 1000...
My exp 1000 sudenly stops , the counters reset to 0 all the lights are on but the control pannel is nonresponsive an error code 07 showed up once. Any ideas?
I don't have any suggestions for fixing it but I wanted to give you a resource should you need to purchase a new motor control board, you can choose your specific model and browse parts list here. Hopefully you can get it to work though, depending on the model it looks like a replacement can run you $100-$200.
Feb 21, 2011 | Nordic Track Nordictrack Exp 1000...
I have a norditrack exp 1000x, on the lower part,of the control panel,the functions,have stopped working.but the upper function keys are ok.what do think is wrong.?
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
Aug 11, 2010 | Nordic Track Nordictrack Exp 1000...
Reebok Vista Treadmill - RBTL13305 Logo
198 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
