Question about Pioneer CDJ-100S CD Player
Cdj100 pause seems to skip, and slow loading
I have 2 cdj100S, one is just fine and the other has a much slower load time.when I play a track on it then hit pause, it doesn't exactly pause, the time display jumps around anywhere from 5 to 20 seconds ahead and the sound does the same too. this makes it impossible to cue an exact point.
  • treb4c41 Feb 17, 2009
    the cdj100s is from september 2000 (thats what it says on back) bought this pair on ebay the guy said they were working fine
  • Pioneer Master
  • 13,433 Answers
How old is it and do you still have warranty on it? seems like some maintenance is needed to fix the problem. I would personally suggest pioneer repair service in this case.
Cleaning the lens might help a little, but thats probably not the problem. The problem is most likely in the drive, or its control mechanism.
Posted on Feb 17, 2009
  • Ekse Feb 17, 2009
    ok thats definitely out of warranty. there should be a 3 year warranty and thats out already.
    well what can I say, its 9 years old soon.
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
On
this is the result of a bad tracking rail and motor. replace the optical assembly asap to combat this issue.
May 26, 2009 | Sony Audio Players & Recorders
My Samsung YP-U3JQP 2GB MP3 player skips past most of the tracks.
Many WMA's are DRM-protected - the DRM-protected tracks that you have loaded may not have transfer rights, even though they will play fine on a computer. The best bet is to download only songs that are in mp3 format. Another option, which is illegal, is to buy a DRM-stripper and strip your WMA's of the DRM-protection - but, it is illegal, costly, and time-consuming.
-Tha Mp3 Doctor
Feb 22, 2009 | Samsung Audio Players & Recorders
The sound on my gateway skips...lllamp...viddddeo...yestttttday. help!
is the video loaded completely? do you have a slow internet connection?
the pause/skip is because the playback program doesn't have data to play. Does your pc have enough RAM? are you on cable internet?
Oct 12, 2008 | Computers & Internet
Cdj-700s
Hi Je remy
I have a 700s too, it´s showing problems similar to yours. Mine is even worst, it almost doesn´t play no more (shows "NO DISC"). Sometimes, when i turn it off and on, or open the cover, it reads... When pause is pressed, it holds the music for some seconds, then it "slides" thru the music... Sometimes it display an error message (something like E-8something).
I think all these errors are caused by a worn optic reader, but i´m not sure. I´ve already opened my unit and cleaned the lens, but no bail.
Here in Brazil a new optic reader can be found for R$150 (around U$90). I´ve just found out the same unit in UK for 150 pounds, so i´m suspicius that those units sold here aren´t really new... I´m planning to replace mine, but first i must be sure that the problem is really caused by the reader.
I don´t know if u have already opened yours, but it´s pretty simple to replace the unit, just some screws to loose (12, if i´m not mistaken - 4 ouside, 4 holding the lens protective cover, and 4 holding two inox sticks where the reader slides over). 700s´ units are Part No DWY1067, and you probably won´t find those anymore. You´ll only find the DWY1069, originally found in CDJ-100s (technically almost same, but probably some newer technology), but they´re totally interchangeable.
Hope could be of some use.
If u want, can contact me at nandoseiji@hotmail.com
This is the unit seller here in Brazil:
http://www.quebarato.com.br/classificados/unidade-otica-optica-leitor-para-do-cdj100-cdj-100-cdj-100s-cdj100s-cdj-500s-cdj-700s-dwy-1069-dwy1069__181502.html
http://www.eletronicamaster.com.br/produtos.asp?produto=3991
Mar 28, 2008 | Pioneer CDJ-700S Turntable
Player stuck in scan mode
Hi...
Unplug it from the wall...give it a couple minutes. Try playing a CD again (using manual controls) If that works , your remote might be the issue.
If you bought the thing new you paid good $$ for it.
It's worth having it looked at by a Pro.
Oct 22, 2007 | NAD C521 CD Player
Cdj issues
Are you getting error messages? If you hold down the pause button for 10 seconds on that model , you should get one.
Keep me posted.
Oct 19, 2007 | Pioneer CDJ-100 Turntable
Bad playback
have same problem, get dvd error message "disc error unable to read disc
Oct 03, 2007 | Samsung DVD-V1000 DVD Player/VCR
Pioneer CDJ-100S CD Player Logo
83 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
