Question about Dryers
Maytag dryer won't heat
Dryer will tumble but won't heat. Timer does not advance when dryer is running
  • Anonymous Apr 18, 2009
    I have the same problem, however before the dryer stopped heating it also was blowing the circuit breaker.
  • 150 Answers
Sounds like your heating element is burned out (acually burned threw) and you will also need to replace the cycle timer.
Posted on Feb 17, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My Kenmore Elite 110.62932100 won't tumble or heat up.
try the homes 240volt circuit breaker it may not show its tripped but one of the 2 phases can trip out, (just reset the breaker) and if this happens either the dryer drum motor will turn or the timer will run, but not both as these 2 components each use 1 of the 2 phases 120 volts to run,but the heating element needs both 120volt phases for 240volts for the heating element to heat,this is what your issue sounds like to me,hope this helps
Dec 09, 2012 | Dryers
Dryer won't shut off.
Will the timer advance in the NO HEAT mode? If it does advance you would know it has something to do with the temp alright but if it don't advance in No Heat then the timer motor is bad in my opinion. And it can fail by more than one way. Open winding OR stripped motor gear.
Aug 30, 2012 | Maytag Dryers
Dryer not blowing hot air- timer not working
im assuming your on the automatic cycle. on this cycle the timer will not advance without heat. check you house circuit breaker/fuse. if one goes the unit will run but will not heat.
Feb 08, 2010 | Dryers
My dryer works ...tumbles ...heat works...timer stay where you put it when you start it..maytag dependable care plus dryer
Your timer motor is bad. It is very similar to a clock motor and it drives the timer on your dryer.
Oct 08, 2009 | Maytag Dryers
Tumble dryer will not dry
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 19, 2009 | Dryers
Maytag electric dryer won't stop running.
temp selection switch is defective, replace.
nbcrca:)
Apr 11, 2009 | Kenmore 64902 Electric Dryer
Electeric dryer model # seds800mqo
could be thermal fuse or bad heat element
Mar 12, 2009 | Whirlpool Dryers
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Maytag lsg7806aa not stopping
Oct 25, 2008 | Dryers
Dryers Logo
85 people viewed this question
Top Dryers Experts
