Question about Sanyo DP42746 42 in. Plasma Television
42" Sanyo HDTV with 3 HDMI Inputs
Ok so I have my PS3, XBox 360 and my Direct TV HD DVR all hooked up via HDMI cables. Everything was fine tell about an hour ago when all three no longer work and it says NO SIGNAL floating around a black screen in a blue box. I have tried to change the order of the HDMI set up, un plug at both ends, unplug TV etc... to no avail. Help me out with this please, what a waste of electronics to be just sitting there!!!!
  • jaredjes Feb 20, 2009
    Still no luck with my 42inch Sanyo, may need to have a TV repair man come out!
  • suzannecrane Feb 26, 2009
    I have the same problem my Sanyo DP42746 42 in. Plasma Television after 18 months of owner ship just went black and volume went out. although green power light stays on. repairs are around 800 dollars what a rip! I smell a law suit..
    President:
  • 1,077 Answers
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Posted on Feb 17, 2009
I have a Sanyo HD flat screen model DS27930 and I'm not sure how to hook up my XBOX 360 to it. ;3;
On most flatscreens there is around four HDMI inputs. Any of these should work. The HDMI should connect from the Xbox to the HDMI input on the TV which is usually on the side of on the back.
Jan 29, 2016 | Microsoft Xbox 360 Console
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
How to hook an xbox 360 to direct tv
What do you have coming out of the xbox 360, HDMI or RCA? The same question for the direct tv?
Apr 04, 2017 | Microsoft Xbox 360 Console
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
XBOX 360 Elite HDMI SOUND PROBLEM
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Nov 25, 2008 | Microsoft Xbox 360 Elite Console
Sanyo DP42746 42 in. Plasma Television Logo
1,261 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
