Question about ASUS Computers & Internet
Computer will not boot.
I bought all new parts: Motherboard, processor, hard drive, video card, memory and power supply. I have plugged up Motherboard, processor, powersupply and hard drive. I have power but the system will not boot.
please help
  • rbartell1 Feb 17, 2009
    All I have is new parts. But the parts are ASUS M3N72-D motherboard, AMD Athlon 694 X2 5400 processor.
  • fixemmaster May 11, 2010
    please list some part numbers so i can assist you
    Master:
  • 461 Answers
Double check all connections and then remove anything not needed. Remove video card and try onboard video if available, remove all but one mem module, any cards and disconnect all drives. If you get video at this point, shut down and reconnect drives and components one by one. It helps if you have known-good parts to swapt as "new" does not always mean good.
Posted on Feb 17, 2009
I JUST INSTALLED A NEW MOTHERBOARD IN A PC THAT IM BUILDING FOR A FRIEND. ITS AN INTEL DESKTOP #D945GCPE IT HAS A DUAL CORE PROCESSOR 2GB DDR2,80GB IDE HARD DRIVE. WHEN I TURN IT ON, EVERYTHING WORKS...
During the boot up process are there any beeps? If so how many short or long? 1 short beep is typical of a normal boot indicating no conflicts. What you can also do is unplug or remove any unnecessary peripherals (i.e. Hard drive, cd drive, any expansion cards) So that all you have is the the power supply, monitor cable, motherboard, cpu, and memory plugged in and attempt to boot. If this is successful add one peripheral at a time and boot again untill the boot fails again. This will usually indicate a problem with the power supply, either its faulty or not providing enough wattage to support all the peripherals, otherwise its a conflict with the specific peripheral that causes the failure. IF none of that works attempt to reseat all your connections, cpu socket, memory socket, power supply, and video cable. If all that still fails it is most likely a bad motherboard, its not unheard of to receive a DOA motherboard. As a last ditch attempt you can determine is a faulty video chip or the motherboard itself by installing a pci video card and seeing if its successfully boots.
Oct 10, 2011 | Intel Computers & Internet
How to build a or assemble a computer and troubleshoot?
Building a computer will require: a motherboard, a processor, memory, a video card or motherboard with onboard video, a sound card or motherboard with onboard sound, at least one hard drive, a CD or DVD drive, a case for the computer components, a power supply, fans to cool the computer, an operating system, a monitor, speakers, keyboard, mouse, 2-3 hours to assemble the computer.
You must ensure that all of the components are compatible with one another. After receiving the parts, lay everything out on a large, clean surface. Make sure you are grounded by touching a metal surface; this will prevent the transfer of static electricity to your computer components.
Typically, the steps to install the components are as follows: 1. mount the power supply in the case, 2. mount the motherboard 3. lock the processor in the socket on the motherboard 4. insert the memory sticks into the slots on the motherboard 5. mount the processor fan on the processor 6. insert the video card into the applicable slot on the motherboard 7. insert the hard drive into a hard drive bay in the case, 8. insert the CD drive into a CD drive bay, 9. mount any fans you have to the fan cutouts on the case 10. connect all applicable data cables to the CD and hard drives 11. connect all applicable power cables to the motherboard, video card, processor, hard drive, CD drive, and any other components. 12. connect the front panel USB, power, lights, and reset connectors to the motherboard 13. close the case 14. connect the power, monitor, speakers, keyboard, and mouse to the computer
Because this process is rather involved, I recommend following a guide such as this one: http://www.maximumpc.com/article/how-tos/how-_build_silent_gaming_pc
It details the process, includes pictures, and even provides a list of compatible parts.
Jun 19, 2011 | Computers & Internet
Before booting 3 long beeps 10 sec silent then 3 long beeps and so on
This is an issue that one of the devices is not properly seated on the board or it is not detecting them correctly.
To fix:
1. Remove all devices from the board. All cables coming from Hard drive/CD-rom. Remove the RAM and processor. LEAVE TH E POWER SUPPLY CABLES CONNECTED TO THE BOARD.
2. Re-seat the processor on the board.
3. Re seat the memory on the board.
4. Now re-seat the video card making sure that you push it firmly in place. Connect a monitor to the video output.
Try and boot the computer. If it boots and you see output on the screen then the issue is fixed.
If if does not boot you have a problem with one of the following: RAM, Processor, Video Card, or motherboard.
Oct 30, 2010 | Asrock K7VT4A-Pro Motherboard
I have just built my own computer. After I set it up the monitor says. No signal coming from computer. Going into power save mode. What is wrong? I have checked the wiring.
That message is telling you the monitor has power and is connected to the computer, but that there's no video coming in. This means that either the computer's never starting up, or there is a problem with the computer's video card.
Do you know for sure that the computer is actually starting up? The power may be coming on, but nothing is going beyond that. Check any jumpers on your motherboard to be sure they are in the proper places. Most boards don't have any, but yours might be different. There is often a "clear CMOS" jumper near the backup battery on the motherboard. Some boards ship with the jumper in the "clear" position, and this can prevent the system from starting.
Make sure you have both power supply connectors plugged firmly into the motherboard. There are two: the 20- or 24-pin main power connector and a 4-pin connector for processor power. Then install only the memory, processor and cooling fan. If your motherboard doesn't have integrated video, plug in the video card as well. Don't install any other cards or the cables connecting hard disks and optical drives. You want to see if the system will start with the minimum hardware.
If your computer starts up and displays video with the minimum hardware installed, put everything else back together and try it again. If everything is normal, you may just have had a loose power supply connection. If you're back to a no-boot condition, one of the other parts is causing the trouble. You'll be able to isolate which is the culprit by removing one piece at a time, then restarting the computer. When you disconnect the bad part the problem will clear up, and you'll know what you need to replace.
If your computer continues not to start up with only the minimum hardware connected, you have a bad power supply, motherboard or processor. You'll need to figure out by parts substitution which one it is.
It can be a frustrating process, but you'll get the computer going. Good luck, and thanks for using Fixya!
Oct 01, 2010 | Computers & Internet
I have a HP media center m7360n , with a 920 intel pentium D processor. I changed the video card which required a more powerful power supply. I upgraded the ram and changed the power supply out to be...
Open your computer casing where the motherboard lies in and then remove the memory card, your new video card and then reset the BIOS, refer to the motherboard manual on how to do it. After resetting, plug in the memory card and video card. Close the casing and connect all the wiring. Power up your computer.
Nov 03, 2009 | HP Pavilion Media Center TV m7360n...
Not booting up
try changing your memory or your processor. you might get a result
Jun 11, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Barebones troubleshooting
Lex -
I would first check your ram, make sure its the right type and rating for the motherboard. Although most systems will beep at post for a memory issue, sometimes reseating the memory alone can clear up a startup hang.
If the memory is seated okay, the right type and speed rating, try using a different video card in the system. Its possible that the system is starting up normally, but not being displayed.
If neither of those help, minimize the system. Plug in just the bare minimum needed for operation - Power supply, processor, heat sink & fan, a single memory stick, a single hard drive, video card(if its not integrated on the motherboard). Plug in a monitor and the power cord, then see if the system boots.
If all that still fails, verify that the CPU fan AND the Power Supply fan are spinning when power is on. If so, this points to either a bad memory stick(try another), bad processor(if available, try one at a slower or faster speed), or bad motherboard.
Hope this helps!
-thinstatic
Jun 13, 2008 | MSI MBOX KM4M-L (ms-6734bb-040) Barebone
Pc wont boot
Have you recently experienced a power surge or had an electrical (thunder) storm in your area? Potentially your motherboard and/or processor could be toast since the fan running and CD Rom drive opening will continue to function because they receive power separately from the motherboard via the power supply. If you have access to a different compatible processor, you could try to install it in the motherboard to rule out a motherboard failure, otherwise you're looking for a new motherboard.
Jan 12, 2008 | Computers & Internet
Computer Not Booting Up
Are you running one or two video cards?
If just one, 550w should be plenty of power. Double check ALL connections and make sure that the ram and all add-in cards are FULLY seated.
Also check to see if the video card requires its own power plug. If it does, it will have a connector on it for you to attach a lead from the power supply.
Also make sure that you have both power connectors plugged into the mainboard, theres one thats only 4 pins and then of course the larger one of 24 pins.
If all connection look good, then start with the basics. Break it down to just the power supply, mainboard, cpu, one stick of ram and the video card... unplug everything else from the mainboard including drive cables and any add-in cards. And check to make sure you processor is seated properly as well as the ram and video.
Let me know what you find.
Oct 23, 2007 | ASUS P5N32-E SLI PLUS (0610839148967)...
No video
It's not necessarily the video that's the problem. Anything that would keep the computer from beginning the POST process (beginning of the process of booting your computer) could also result in no video. When you start the computer up, does it beep at all? If so, how many beeps, and are they long or short. The order and lengths of the beeps are the most basic type of error codes. Also, do you hear the hard drive spinning up? And does the CD/DVD ROM drive start up normally? It could be a power supply, your processor, memory, the motherboard or just the video card. It could also be just about anything in the computer if it developed a short, as a single short can cause the power supply to shut itself down so as to protect the computer from being further damaged. I would suggest disconnecting power to the drives, and trying again. If it boots to video, you know one of the drives is the culprit. If they aren't the problem, try removing the memory. It won't boot that way, but if the memory is the problem it will at least reach your POST and give you the option of entering BIOS. If you get that far, the memory is at fault. Then, try the same with any expansion cards onboard. If none of that causes it, then you either have a bad processor, bad onboard video, something else wrong with the motherboard, or bad power supply. Unfortunately, none of that can really be tested without having parts to swap out.
Aug 28, 2007 | Dell C521 DimensionTM PC Desktop
Computers & Internet Logo
104 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
