Not staying on
Dell laptop i press the power button but cuts off after a few seconds
  • einkampfer Feb 17, 2009
    I have tried plugging it back in and out makin sure the battery is in properly an nothing works it's starting to rive me nuttier tryin to fix it
  • Frank Simard
    Frank Simard May 11, 2010
    Is the laptop charged? Try plugging it in the power outlet and try it again.
  • 265 Answers
Proberly due to over heating matey,
try replacing the thermal paste on the CPU
if its still in warrenty then give dell a ring :)
Posted on Feb 17, 2009
I charged my tablet and turned it off for a few hours and now it wont cut on
Press and hold power button for a few seconds.. To run safe mode.
This is a common problem caused by power fluctuations.
Nov 12, 2015 | Tablets & eReaders
VOSTRO 1320 doesn't turn on
That would leave the processor ic, usually most motherboards do not include that.
May 05, 2012 | Dell VOSTRO 1320 13.3-Inch Laptop (2) PC...
Dell 1545 will not power up
SOUNDS LIKE A BAD MEMORY STICK
Dec 26, 2011 | Dell Inspiron 15 Laptop
Dell laptop is not getting on, when i press is power switch on button the lights burn only for few seconds but again it is getting off and their is no display at all.
When you press the power switch on your laptop, the lights turn on only for a few seconds then they shut off? It will not power on at all?
Make sure that your battery has a charge. Leave the laptop plugged in for 10-20 minutes and see if it will power on after that. If not, you have a couple of options to try.
-Try a different laptop battery. The one you have may be damaged.
-Try a different power cord.
-Try a different wall outlet.
If none of the above solutions work. you may want to contact Dell technical support for further assistance.
Click here for dell tech support
Regards,
G33k
May 10, 2011 | Dell Latitude D600 Notebook
I have an intermittent power-on issue with my Dell E4200. Sometimes it is very hard to turn on - pressing the power button makes the button light up, the fan runs for a few seconds, then the caps lock icon...
Try performing a hard reset on the laptop. Remove the battery and all peripherals connected to the laptop (including the AC adapter). Once everything is removed/disconnected, press and hold the power button for around 15 seconds. This will drain all remaining charge in the motherboards capacitors which usually causes this kind of issue.
Hope this help. Goodluck!
Mar 28, 2011 | Dell Latitude E4200 Notebook
I working on my sister Dell Studio laptop. Her son got a hold of it and pressed the power button several times while pressing several buttons. Now the laptop does not boot correctly. I power it up and the...
Remove battery and AC power, press power button for 30 seconds. reconnect ac power and try again.
Also check the hot keys (brightness) usually Fn and F6, see if that help
Dec 29, 2010 | Dell Studio 15 Laptop
I have a Dell Latitude D500, The problem however, is that a times, the laptop will not turn on (power on), instead it will go into a power-on / power-off cycles. It will stay on for few seconds and then...
hi
please insert the windows boot disk and enter in the bios ..select booting option for cd drive...........
..............most probably you may have to reinstall....
if failed the problem may be with the display settings ...it is better to approach an expert or service center ........display settings options are in bios and an expert can only slove it......
thank you
hope you do it soon.......
Oct 29, 2009 | Dell Latitude D600 Notebook
Laptop will not boot. The power light flashes
CLICK HERE
the codes which you see are universal for all the dell laptops. find the appropriate. this will solve your purpose and guide you how to go furthur.
Sep 26, 2009 | Dell Inspiron 1521 Laptop
My Dell Inspiron 1000 Laptop would not power up.
possible power supply are motherboard possible bad pin on board
Mar 28, 2009 | Dell Inspiron 1000 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
