Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman Garage door opener not working
Neither the remotes or the hardwired opener will open the door. Checked the sensors, they align, there is a green flashing light on the actual unit. When you push the opener, the unit just hums for two seconds and the green light flashes on the unit. I tried resetting the unit by pushing the green reset button by the green light. I also held down the opener button, it still does not work. Any ideas?
  • 118 Answers
First, check the springs in the actual door to make sure that they are not broke. Since you held the learn button down to reset the opener, you have to reprogram all of your remotes. This button only resets the remotes. It has nothing to do with the rest of the opener. To reset the opener, simply unplug it for a couple of minutes and then plug back in. Pull the handle on the door and see if you can operate the door manually with one hand. If it takes more than 15lbs to move the door, there is a problem with the door balance. If the springs are not broke and the door operates smoothly, the likely cause is the rpm sensor on the opener.
Posted on Feb 17, 2009
I have a 3/4 hp Craftsman garage door opener. The wall consule unit is working intermittently - it doesn't always activate the door opener. When it does work, the small light on the push button is lit...
Is your unit hardwired? If not batteries are likely issue, if it ever corroded, due to battery leak, the connection fails early on subsequent batteries..Consider anti battery acid gel.
if it is hardwired, look for damage on wiring. something laid against the wiring or controls...
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote capability out on garage opener
If you are having a problem with all your units that transmit a radio signal it is your receiver that is going bad. It is part of the logic board.
Jan 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hardwired code opener no longer works
Here are the directions to program your hardwired keypad.
First unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
6 month old garage door will work.
On the back of the opener near where all those white wires go you will find 2 controls. One is labeled "up force." Increase this about 1/4 turn.
May 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only works partly
some thing blocking sensor or laser is not in proper alinement
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener /
door will not go down unless you hold down the inside botton.
Sep 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door
Are the sensor lights located on each side of the garage door opening? Have you checked to see if they are in alignment with each other? Also check to see that any wire from the sensors are disconnected on the motor or at the sensor itself. Good Luck! Countrycurt0
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Jun 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
293 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
