Question about Linksys Wireless-G Broadband Router
KEEP GETTING ERROR 321 WHEN SETTING UP LINKSYS WRT54GS ROUTER
HAVE CABLE INTERNET SERVICE , TRYING TO SETUP WIRELESS ROUTER FOR WIRELESS INTERNET ON NEW LAPTOP. FOLLOWED DIRECTIONS EXACTLY AND KEEP GETTING ERROR 321 CABLE NOT CONNECTED. PLEASE HELP
  • Linksys Master
  • 4,338 Answers
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 07, 2009
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
Set up for unit CGN91F5G2439
If I am not wrong then this number ( CGN91F5G2439 ) is serial number of WRT54GS v6 router.
You can setup Linksys WRT54GS router without CD. Connect your computer to the modem and make sure that modem is getting active Internet.
Connect the computer to the router and modem to the router. OPen the setup page of the router and change the Internet connection settings of the router.
Nov 05, 2011 | Linksys Wireless-G Broadband Router
I have been running a Linksys BEFSR41 version 2 wired router for over 5 years without any problems. My wife is a teacher and her school p[urchased new laptops recently so I decided to go wireless. Got on...
I think the most likely problem is that both routers are using different IP address ranges and won't allow data to pass between them.
I suggest you use only the Linksys wireless router.
Nov 17, 2010 | Linksys Wireless-G WRT54GS Router...
Setting up linksys wireless router security wep . Linksys WRT54gs V.5 router. I reset it back to factory defaults. Now I want to make it secure again.
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 07, 2010 | Linksys Wireless-G WRT54GS Router...
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
Error 321 'ethernet not connected' on LINKSYS WRT54GS
Dont go with the error , i came across such instances on a few occasions while users were installing it from CD . (Sounds lamme?right)
Try doing the set up manually , by accessing the web Gui of router .
***FOLLOW THIS********
The GS comes set to 192.168.1.1 as its factory default and with its built-in DHCP server enabled. So all you'll need to do is plug in a client that's set to obtain its IP address information automatically, maybe do a DHCP release / renew (or reboot your client computer), and enter the default password into the login box that pops up. If all goes well, you'll get the main Setup screen.
The Internet Configuration Type selector automatically refreshes the browser screen to present settings appropriate to the choices of Automatic Configuration - DHCP, Static IP, PPPoE, PPTP and Heartbeat Signal (for Australian users) Internet connection types.
MAC address cloning gets its own page in the Setup section, as does setting up either dynamic DNS service from dynDNS.org or TZO, setting up static routes or disabling NAT features and converting the GS to a non-NAT router.
The interface is generally quick, with quick mini-reboots needed to get the changes you make on each page to take. Multiple admin logins are allowed, with no warning given when two or more admins log on. Once you're logged in, there's no idle timeout, and you just need to remember to quit your browser when you're done, because there's no logout button.
Enabling Remote Management for the first time still pops up a message telling you to change the router's default password and you can now enable secure (HTTPS) admin access. You can also change the default remote admin port from 8080, but can't restrict access by IP address or domain. Also of note is that you can't reboot the GS from the Admin interface.
Let me know if you require any more assistance.
Apr 18, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
166 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
