Question about Zenith C27A24T 27" TV
T.v. lost channels.. did input search it says no channels found?
Can't get channels to input . i've unplugged it... tried to manually add channels etc...My Tv is a 27" Z27A12S and have the same type of problem, dosn`t pick any channel even the input, if somebody can give me a hint how to solve this problem, I`ll be very thankfull.
    Brigadier General:
  • 8,619 Answers
Hi!
Try tuning the channels on other video channel like AV2. Or try tuning it on channel 3 or 4.
When tuning please see the band selected- uhf or vhf.
Posted on Feb 17, 2009
  • Rylee Smith
    Rylee Smith Feb 17, 2009
    Also, you can download the manual from the link----
    Zenith User Manual
    Please ask for further clarifications
    Please rate this solution as fixya if found helpful.
    Thanks
    Rylee
  • Zenith Master
  • 13,433 Answers
Can you try another tv at your home to see if your getting any channels right now? if another tv shows channels then theres a problem with your tv.
I have a peavey cs800 s that has no output on channel B. im hoping someone can tell me the first few things i can check. its not the input source or cables i do kniow that much. havent found any loose
Switch inputs, switch speakers, if not you need to open it up(unplugged from power) and do a visual inspection.. possible bad power/output transistor(s)
Apr 11, 2013 | Audio Players & Recorders
Sharp aquos 60 inch. Setup ok went thru ez scan for channels then not sure if i hit something getting settings right but now all it does is repeatedly tell me to search for channels even right after it...
Look in the menu to see if in catv or cable band or air band for antenna and you do have a way around this if using cable box or sat box---connect box via the jacks on the rear of the box (component or composite--component being better) and hook up to the correct matching input on rear of set--select that input on the set and change channels etc via the box.
Also try to unplug set for a short time and go through the setup again, be patient as a channel scan can take several minutes in some cases
Let me know what happens of if you have questions
Dec 06, 2012 | Televison & Video
Will not find digital tv stations
I'll be glad to assist you in locating the digital channels in the TV.
Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box.
To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database.
This should resolve the issue. Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Aug 04, 2011 | Sanyo DP46848 LCD TV
Lost instructions
If you let me know what the exact model number and brand name is of your shaver, I can give you more specific help, but otherwise this is what you should do:
1. Look at your shaver and try to find the Brand Name and model number.
2. Once you've found it, the best thing to do would be to type into www.google.com a search query in the following format:
Conair 5GC85 Electric Shaver Manualmake sure to add the "manual" at the end after the Brand Name/model number. This search should give you a few useful links right at the top of the page, so just try the first couple links.
May 18, 2011 | Health & Beauty
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Digital channels lost on DVD recorder
I'm delighted to report that all is now working.
I turned the recorder off at the mains electricity supply, left it off for several hours, switched it back on, searched for new digital channels, and it found them all :-)
I had tried this before, but only left it disconnected for a few minutes, and clearly that wasn't enough.
Sep 08, 2009 | Panasonic Televison & Video
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
Lost remote want to get to input channels using side buttons on TV
Try using the manual buttons and keep pressing channel down until you see the lowest station you receive, then go slowly.
Maybe Insignia put the inputs into the channel search automatically.
Apr 27, 2009 | Insignia LCDTV26 26 in. Television
FRIEND HAS A SONY FXE 100 AND HAS LOST THE MANUAL. THE COMPOSITE VIDEO INPUTS AREN'T WORKING...BEEN HELPING HIM SEARCH FOR A SERVICE OR OWNER'S MANUAL WITH NO LUCK. ANY HELP YOU CAN OFFER? THANKS!
Chances are that the composite inputs are not selected in the settings. You need a display connected to the MONITOR output to see what you're doing. Then press the SCREEN button (just below the RECORDER readout) until "Menu" lights up next to it. Then press the large round wheel in while keeping the MENU button depressed - this will bring up the menu settings on the monitor. Then press the MENU button in the "Dial Menu" section - while keeping it pressed, rotate the large round knob until "Setup Item 101" appears in the display- this is the Video Input Select area.
Release the MENU button to select Item 101 - then press the DATA button while rotating the large round knob until S-V changes to V (going from S-Video to Composite ). When you've reached the desired setting, press the SET button to store it in memory. Keep in mind that you have to do this on P1, P2, R and/or AUX depending on which channels you want to change. The factory default is S-Video, so that is probably how the machine is set on each channel. When you've finished setting the channels to your preference, press the SCREEN button to exit the menu.
I've found that the $20 (or so) investment on one of the many manual sites pays for itself many times over in "frustration control". I can attest that www.servicemanuals.net is quite trustworthy, and in most cases you can download and print the manual immediately. The sites that offer "free manuals" are more trouble than they're worth as you have to download all kinds of crap you don't need, and they pop up when you don't want them to and slow down your computer. If you need more help, write me at barry8track@cableone.net
Jan 14, 2009 | Sony DSR-20 DVHS VCR
My Vizio plasma TV won't change channels with the remote or side buttons, but if I input a channel number, it will change that way.
Try unplugging the TV for a few minutes and then doing an auto channel search through the menu button. That has solved my problem, at least for the time being.
Aug 11, 2008 | Televison & Video
Zenith C27A24T 27" TV Logo
138 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
