Question about E-Machines eMachines Desktop PC
Buy a new monitor but my desktop is not reading it. both emachine
I can see it on my laptop but when I start my desktop the monitor read no signal.
  • E-Machines Master
  • 13,433 Answers
Hey,
Theres a problem with your desktop, its not starting up properly.
I would suggest you take the desktop to someone who can test it and look into it.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
Emachine T2240 computer, powers on no signal on monitor. Power goes on, but no video?
When power supply got burned on the computer. A problem arises first in the CPU. If the power supply burned because of a power glits is a different story. try to save your data you probably need to buy a new computer.
Nov 04, 2015 | E-Machines eMachines Desktop PC
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Dual monitor
It appears you have two outputs for video so yes, you should be able to export the video signal for dual monitor use.
Apr 22, 2013 | eMachines E Machines Et1831-07
When I turn on my emachine, it reads:
It means your video card is not out putting to your monitor. If it clears up, it is normal. If it continues, check your video card and/or settings.
Oct 13, 2009 | E-Machines eMachines Desktop PC
My DVD stopped reading my program CDs.
Honestly, if its not under warranty, you can buy a brand new DVD Burner for cheap.
Look here: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136144
$24 for a new drive
Jun 22, 2009 | E-Machines eMachines Refurbished EMA...
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
LCD monitor signs "no signal" on eMachines t3418
E-machines had had a long history of bad power supplies. I've seen many of these machines go bad and when they do they take out the video chip (Nvidea) with it, usually shutting down the whole machine. I've never seen one operable. You might be able to insert a video card.
Mar 23, 2009 | E-Machines eMachines Monitor E15T4
Still having trouble with EMachines T3882
I feel your pain. I finally moved my pc to a room with no windows! But seriously, try a different monitor first. See if you can borrow someone's to just try it before you do anything else. If that borrowed monitor works fine, then you know what the problem is. (Which I believe is the problem.) By the way, what started all of your problems?
Aug 20, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
53 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
