Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca r52wh74 . Double picture .
Picture hard to watch. lines on the top of screen bow in different colors
  • RCA Master
  • 5,138 Answers
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 it will be on right side of FBT flyback transfomer there will be 3 ina roll they are small brown rectranigler looking caps but are FUSES. It will be the one in the middle.
Posted on Feb 20, 2009
I have a Rca Model# R52WH74 the picture looks bowed at the top and bottom and has double vision of objects.
The convergence is out, and the convergence ICs' need change, or it will have to be repair, and it will run around 350, on repairs.
Aug 23, 2011 | RCA R52WH73 Projection Television
Rca r52wh74 bowed picture and 3 d color
Your convergence amplifier has failed.
There are a few things that usually cause that in that particular chassis design, the most likely one being that you have lost part of the power supply to the convergence amplifier power supply board.
You may be able to repair it yourself if you're good at soldering, and dis-assembly / re-assembly.
Look for a 400ma fuse that's opened near the FBT, and re-solder all the connections in that area. Also check to see if any diodes have shorted around it too.
Good luck.
Dec 01, 2009 | RCA Televison & Video
Picture is bent. color is a bit fuzzy and 3 lines
Ur convergence it dead,know how to solder?Buy a convergence kit use what in that kit.Tries websites Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA HD52W59 HDTV Projection Television
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Problem with my rca projection television
my RCA R52WH74 HDTV IS STARTING TO LOOK BLURRY. ALSOMY SCREEN LOOKS LIKE IT STRETCHING MY TV PROGRAMS....... CAN U GIVE ME A SOLUTION
Mar 16, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
